Old 12-21-2005, 08:22 AM   #1
srponies
srponies will become famous soon enough
Default Slight hiccup/stumble while accelerating under load
Drove my wife's '97 SL2 (133k miles) last night and found that it stumbled while lightly accelerating under load. Like when driving in town, 35-40mph, 5th gear, 1200rpm, and giving it the gas it would stumble once or twice while speeding up. Seemed to be prominant when bogged down/ low RPM load.
It has been a while since any work was done on this car. What should I be tackling here first? EGR? ECTS? Plugs & wires? Fuel filter?
One other thing is that for a long time (1yr.+) the car had the check engine light on due to a bad converter (I think that's what the code was). Wouldn't you know I just ordered and received a new cat 2 weeks ago and the light had gone out.
Thanks for all ideas.
Steve H.
srponies is offline   Reply With Quote
Old 12-21-2005, 05:13 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Slight hiccup/stumble while accelerating under load
Sounds like it might be EGR. However, if you've still got a plastic tipped ECTS in there, I'd do that first.
Old 12-21-2005, 06:32 PM   #3
katarn444
katarn444 is on a distinguished road
That is exactly what my bad EGR does. To test it on my 93 I plugged the vac line( which throws a code) and it works great. I am not sure if that indicates bad EGR or EGR solenoid. This only works on the older vac controlled EGR's.
Katarn
katarn444 is offline   Reply With Quote
Rattle Noise From Exhaust System Under Slight Load steelerfan4life Vue Tech 12 01-15-2008 10:10 AM
hiccup Markwthree29 S-Series Tech 0 04-30-2007 09:23 PM
Wierd CD player hiccup Vorzer Vue Tech 0 01-25-2006 12:56 AM
major stumble accelerating LDB_2001SC2_#54of99 S-Series Tech 2 08-27-2000 02:41 PM
major stumble/hesitation accelerating LDB_2001SC2_#54of99 Ion General 3 08-27-2000 10:20 AM
