Old 02-13-2022, 01:19 PM   #1
What a VUE
What a VUE is on a distinguished road
What a VUE's Avatar
Default Very poor gas mileage, 07 3.5 AWD
Hello all, been awhile.
2007 VUE, 3.5 AWD 220k on the clock. Not so long since plugs changed, well under recommended interval.
Runs well, seemingly. Recently changed oil and replaced the coolant temp sensor as it had failed and spiked the gage to trigger the overheat indicator. Hoped that was the cause of decreasing mileage but apparently it wasn’t. No stored codes, no active MIL. Mileage has cratered down to about 14-15 highway. I’m a little stumped.
Anybody have any ideas?
Dave
07 VUE 3.5 AWD
What a VUE is offline   Reply With Quote
Old 02-17-2022, 05:45 PM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Very poor gas mileage, 07 3.5 AWD
...Have the o2 sensors checked, depending on miles on vehicle, also which plugs you used, if not the factory plugs, i would get them, check coils ,if they are making solid contact with plugs, just some thoughts, DC.
Old 04-03-2022, 07:15 PM   #3
SL2 Ride
SL2 Ride is a jewel in the roughSL2 Ride is a jewel in the roughSL2 Ride is a jewel in the roughSL2 Ride is a jewel in the rough
2005 ION-3 Sedan
Maybe the injectors?
SL2 Ride is offline   Reply With Quote
Old 04-03-2022, 10:03 PM   #4
What a VUE
What a VUE's Avatar
DC: 200k-plus on the engine.
I’ve considered plugs, coils but no misfire codes. Ever. No O2 codes. I get the feeling I’m going to have to start with a new tune-up, O2s all-round and if that doesn’t work…
Maybe the injectors.
Far2Grumpy’s been trying to help me as well, and it’s got us both stumped.
Dave
07 VUE 3.5 AWD
Old 04-13-2022, 10:16 AM   #5
SL2 Ride
2005 ION-3 Sedan
what have you checked so far?
Old 04-13-2022, 12:48 PM   #6
What a VUE
What a VUE's Avatar
Everything I mentioned. It’s driving me nuts.
No codes. Of any kind. No misfires. No vacuum leaks, no plugged exhaust. Runs smooth and idles smooth. I’m completely stumped.
Dave
07 VUE 3.5 AWD
Old 04-13-2022, 01:11 PM   #7
SL2 Ride
2005 ION-3 Sedan
Well injectors aren't the worst thing to replace...
Well what's the cost of the O2 sensors vs swapping out the injectors?
Oh, and fdryer says to check the external fuel filter.
http://www.saturnfans.com/forums/sho...d.php?t=235861
Old 04-27-2022, 10:42 PM   #8
What a VUE
What a VUE's Avatar
Until he didn't.
I thought of that as well, but realized after scooting under there - they weren't there.
Dave
07 VUE 3.5 AWD
Old 05-04-2022, 03:25 PM   #9
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
Swollen front brake caliper hose?? Just throwing out there as a possibility since there are no codes being set. Does it feel an little sluggish? Check and see how hot the rotors are, unless you are doing frequent, hard stops the calipers should be warm to the touch not super hot.
Saturn Vue: The 250 HP tupperware
newbievueowner is offline   Reply With Quote
Old 05-04-2022, 07:44 PM   #10
What a VUE
What a VUE's Avatar
Brakes are new and fine. Problem pre-dated the brake job as well.
Not sluggish at all, no stumbles, no nothing. That’s what makes this so hard to dx.
Dave
07 VUE 3.5 AWD
Old 05-05-2022, 08:27 AM   #11
newbievueowner
2006 VUE Red Line
Not sure if maybe you misunderstood what I said or whether I missed something in what you might have mentioned. So you have had the front brake caliper hoses changed? On these Vues, the front brake line getting pinched off due to rust on the bracket that holds the hose is VERY common, especially if you live in an area that gets salt put on the roads on the winter. I've had to do them on both the Vue's I owned in the past. Was just a thought/area to look at as you are not getting any DTC's and really crappy fuel economy.
Old 05-05-2022, 09:38 AM   #12
What a VUE
What a VUE's Avatar
Understood perfectly. As I said, brakes are new, includes hoses.
Dave
07 VUE 3.5 AWD
Old 05-05-2022, 02:30 PM   #13
newbievueowner
2006 VUE Red Line
Ok, I have no other idea then at this point.
Old 05-05-2022, 09:00 PM   #14
What a VUE
What a VUE's Avatar
Welcome to the club. 😑
Dave
07 VUE 3.5 AWD
Old 06-30-2022, 08:56 PM   #15
SL2 Ride
2005 ION-3 Sedan
I'm wondering if you ever solved your low fuel mileage.
Old 07-08-2022, 05:51 PM   #16
What a VUE
What a VUE's Avatar
I have not. Haven't been driving it as a result.
Dave
07 VUE 3.5 AWD
Old 07-12-2022, 11:56 AM   #17
SL2 Ride
2005 ION-3 Sedan
Did you ever swap out the injectors? I have to wonder if worn injectors couldnt be dumping more gas in the cylinders.
Old 07-13-2022, 08:24 PM   #18
What a VUE
What a VUE's Avatar
I haven't yet. Going to start with obvious, basic fixes. Plugs, coils, filters, O2 both upstream and downstream.
Started thinking about this again the other day, wondered if a bad EGR could be
causing issues? Also, Honda is now recommending 0-20 synthoil, and that's what the tech has been using for some time. I'm also wondering if the thinner oil is contributing to the problem.
Dave
07 VUE 3.5 AWD
Old 07-13-2022, 10:02 PM   #19
SL2 Ride
2005 ION-3 Sedan
Wouldn't a bad egr or 02 sensor throw a code?
Old 08-01-2022, 11:16 AM   #20
What a VUE
What a VUE's Avatar
You'd think so. But no codes, no nothing.
Dave
07 VUE 3.5 AWD
97 sl2 poor gas mileage hagar71 S-Series Tech 2 04-29-2012 01:02 AM
97 sl-2 poor gas mileage hagar71 General Saturn Discussion 1 04-29-2012 12:46 AM
Poor Gas Mileage George Lopez S-Series Tech 10 02-06-2006 06:48 PM
Poor Gas Mileage? roadkilldave S-Series Tech 19 01-27-2006 02:35 PM
Poor Gas Mileage Smokey S-Series Tech 5 08-13-2003 07:29 PM
