Old 05-07-2021, 07:25 PM   #1
Undertake72
Undertake72 is on a distinguished road
Default 1998 sc2 tach issues still
Ok so here hopefully one last time .. I have the autometer model 2300 tach ...then was told I need the tach adapter to make it read properly .. Bought that .. But for the life of me i CANT get it to work at all ...any help would be appreciated very much .. Tach adapter model number 9117
Undertake72 is offline   Reply With Quote
Old 05-08-2021, 12:15 AM   #2
Default Re: 1998 sc2 tach issues still
Tach Adapter
Red -> +12v
Black -> Ground
Red/Green -> Tach signal from PCM (white wire)
Gray -> Gauge
M2300 Tach
4cyl = both DIP's down
White -> Grey wire on radio harness (or +12v if you want the backlight on all the time)
Red -> +12v
Black -> Ground
Green -> Gray wire from adapter OR White wire from PCM if not using adapter
All +12v references are key-switched sources, not directly from the battery otherwise it'll drain the battery.
Old 05-08-2021, 12:33 AM   #3
billr
Maybe I'm reading the Autometer info wrong, but I don't think the above is correct. I think the 9117 goes in series with one of the ignition wires, after it the wire is cut.
What does Autometer say about all this? Do they understand that you are trying to connect to a Saturn wasted-spark system? If they cannot figure out why it won't work, I would abandon Autometer and start over. Trying to "finish the engineering" for a flaky vendor is not often a practical effort.
However, I suppose I should ask: what does it do now, no tach action at all, or still wrong reading? How, exactly, do you have the wires to the 9117 connected to the car?
Old 05-08-2021, 02:03 AM   #4
Undertake72
Autometer wasnt a great source of help ..they told me to hookup the red wire onto the brown with white tracer off ignition module with the tach adapter then put the red / green wire from adapter to the pcm side of brown/ white wire ...then it should work ...not working at all ...that wire with just the tach reads only 1 cyl ....wtf lol
Old 05-08-2021, 12:31 PM   #5
billr
So, it is reading, but at 1/4 the proper rpm?
I'll check out the wiring connections you described and post again later.
I just re-read you last post, I think it is incomplete. You describe how you connected the RED wire and the RED/GRN wire from the 9117 adapter, but I think there are more than two wires from the adapter (4 of them?). How are the other adapter wires connected, and can I assume the adapter is connected to the ach as shown in the (again, poor) published Autometer info? I will post a link to the info I am referring to in my later post.
Oops,,, no need to post the Autometer info, that was already done in reply #2 by somebody else! Time to study some more now...
Old 05-08-2021, 09:39 PM   #6
Undertake72
Ok so on my tach adapter "per autometer" I connected the red/ green wire to the ignition module side .. Then the red wire to the pcm side of the brown/ white wire then I got no signal at all at tach ... Brown/white wire is cyl 4 signal output .. With adapter tach didnt work ... Without adapter I got 1/4 signal ... The white wire at the module I got half the signal on tach .. Havent tried the adapter on that wire yet ... But I'm not optimistic on that wire either ... Grrrrrrrr
Old 05-08-2021, 11:55 PM   #7
billr
"The Auto Meter Tach Adapter wires in line on the positive 12 volt supply wire. It senses current on the coil positive wire and converts it to a 12 volt signal output."
I think you need to put the RED and RED/GRN wires from the adapter in series with the PNK wire to the ICM (pin A).
Cut the PNK wire and connect the RED wire to the ICM side of the PNK wire and connect the RED/GRN wire to the harness (PCM) side of the PNK.
My understanding is the Saturn ICMs have the coil drivers in the ICM, so the individual coil primary currents are not accessible through any of the wiring. The only way to sense coil current is via the 12V supply to all the coils (the PNK wire). I'm not sure, but I think you will find the tach will now read 2X actual speed, so you will need to jumper the tach for "8-cyl"
Old 05-09-2021, 09:13 AM   #8
Undertake72
I will give the pink wire a try this afternoon ... I will le you know how it goes !!
Old 05-09-2021, 11:24 AM   #9
billr
I got that backwards last night, the adapter RED goes to the harness, the RED/GRN goes to the ICM. And, the PNK in the harness is coming from the "EIS" fuse, not the PCM; but that is an irrelevant error. It was late for me last night; that is my excuse and I am stickin' to it!
I will PM the OP to increase chances of this correction being seen.
Old 05-10-2021, 08:05 PM   #10
Undertake72
I got your pm ... So your saying the red/ grn goes to igm side of pink wire and red goes to pcm side of pink wire ?just to clarify ? Because im about to call summit and exchange this adapter incase I messed it up hooking it up wrong !!!!
Old 05-10-2021, 10:16 PM   #11
billr
Yes, you understood my advice on the PNK wire correctly. Have you tried it yet??? I am eager to see if that works. I'm thinking now that you can leave the tach jumpered for 4-cyl
Old 05-14-2021, 07:41 PM   #12
Undertake72
Ok hooked it up with your update and works perfectly now !!!! Ty very much on the info !!! And btw it has to be in 4cyl mode to work properly !!!
1998 sc2 tach issues Undertake72 S-Series Tech 5 05-01-2021 12:09 AM
1998 sc2 tach siganl Undertake72 S-Series Tech 1 04-24-2021 12:05 AM
Speedo and Tach issues Ericth4 S-Series Tech 5 05-01-2011 08:27 PM
got a 1998 SC2 - some issues. genewitch S-Series Tech 41 05-17-2010 07:24 PM
Speedo/Tach issues Keeter S-Series Tech 1 10-11-2009 06:11 PM
