Old 04-11-2021, 05:42 PM   #1
ProOpel
ProOpel is on a distinguished road
Default Fuel Pump Service Port Mod
Folks, I finally did the fuel pump mod. My friend and I cut an access service door like the euro Astras have. Be careful when you cut the metal, we cut a few cables and hoses because we weren't careful. But, overall, this is a far cheaper, much faster and easier way to access and replace the pump. Metal is easy to cut through, we used regular tools.
I'm now thinking of replacing the motor. Please check pit of motor. Aftermarket motors have one single inlet, but the OEM unit has two. Do you know what the second inlet is for? Here's the aftermarket unit I'm considering:
https://www.ebay.com/itm/12V-255LPH-...53.m1438.l2649
It only has one inlet.
08' Astra XE 5dr
5 spd manual
team2fast 200 sportcat
Autolite XP5224 spark plugs
GM valve cover/PCV (55564395)
Side skirts
SRi top spoiler
SRi rear bumper skirt
ProOpel is offline   Reply With Quote
Old 04-20-2021, 08:08 PM   #2
Astra08
Astra08 is on a distinguished road
Astra08's Avatar
2008 Astra XR
Default Re: Fuel Pump Service Port Mod
Wow! Not for the faint of heart.
Very meticulous work.
Astra08 is offline   Reply With Quote
Old 04-21-2021, 03:57 PM   #3
ProOpel
hey man. It's not straightforward indeed, but if you're careful it's way much easier than dropping the tank and all the other components requiring to access the pump and it will save users tons of money.
I just didn't want to do all that work that would have taken half a day without a car lift. I was on the road within a couple hours, but we could have finished it off much earlier had we not accidentally cut the wires.
By the way, I just got the new motor fuel pump in my old assembly, and will be testing it soon. I purchased a cheap $17 255LPH fuel pump motor (only the motor) to replace the faulty one in the system. It came with a filter, and a few bits. I was able to re-used the hoses in the pump and all fit perfectly. Only issue is I dropped the little motor to the ground (1ft height) so I hope I didn't damage it!
But if this additional mod works, you can save even more $$ as you will only have to replace the motor and filter instead of having to purchase the whole pump assembly which goes for $200-$300 when only a few things need to be replaced. It ain't worth it.,
I plan to take a video if this works.
08' Astra XE 5dr
5 spd manual
Side skirts
SRi top spoiler
Old 04-22-2021, 04:25 PM   #4
Bill Murray
Bill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the rough
2007 ION-2 Quad Coupe
1997 SC1
I've pulled tanks on several cars and pickups and didn't think it was all that difficult. Just make sure it's almost empty, not really that heavy, build a "cradle" out of random lumber that distributes the load so you don't dent the bottom and can match up with your floor jack.
IIRC the weight of a steel Camaro tank was 25 lbs. empty
Old 04-22-2021, 04:57 PM   #5
ProOpel
It depends on the person.
But it's extra steps for something that can be done quicker and easier. After having replaced a fuel pump on an older E30 bimmer while on the way to FL, if the tank had to be dropped, I'd have been stranded and had to call a tow truck and put in a shop. Thankfully I only needed to lift the back seat, remove the lid, and within 30 mins I was back on the road. So, after that situation I was sold on service doors. All cars should have this.
08' Astra XE 5dr
5 spd manual
Side skirts
SRi top spoiler
Old 04-26-2021, 08:49 PM   #6
Astra08
Astra08's Avatar
2008 Astra XR
Please post it if you do. There are certain design aspects of cars which I simply don't understand, and this arrangement with the fuel pump has to be one of them.
Old 04-26-2021, 11:42 PM   #7
ProOpel
Will post an update for sure, been working on my other car lol. I'm looking forward to see if there's a boost in performance.
08' Astra XE 5dr
5 spd manual
Side skirts
SRi top spoiler
Cutting access port for fuel pump. Yes? No? ProOpel Astra Tech 29 10-14-2020 11:52 AM
A/C service port valves Petey S-Series Tech 3 07-30-2020 12:34 AM
AC service port caps nwgator S-Series Tech 2 04-03-2013 05:24 AM
Is the high side A/C service port a one way port? MadPuppy S-Series Tech 8 06-14-2012 06:02 PM
what 2 ports on the diagnostic port connect to run fuel pump 94503 S-Series Tech 2 09-29-2007 12:45 PM
