Old 02-27-2021, 09:26 PM   #1
CGrattan86
CGrattan86 is on a distinguished road
Question 1995 Saturn SC2 Instrument Cluster Swap
So, I've inherited my fiance's 95 SC2 that she got during High School in 2003 & due to an electrical shortage/fire has rendered most of my gauges useless. Just yesterday I swapped out the cluster & have restored functions of everything except the following:
  • Fuel Gauge
  • Coolant Temp
  • Signal Lights
  • High Beam Indicator
I haven't got the slightest idea which wires go where except for what I can kind of understand using the wiring diagram. Does anyone have a link to a more in depth guide w/possible color codes & what not? I'm completely out of ideas.
CGrattan86 is offline   Reply With Quote
Old 02-28-2021, 12:43 AM   #2
Default Re: 1995 Saturn SC2 Instrument Cluster Swap
Seems smarter to just pull the harness from another '95 SC2.
The big file has 4 pages to the other 2 files 2 pages, might be duplicates.
File Type: pdf 1995 Coupe Cluster Turn-Hi-Telltales-Dim illum.pdf (72.3 KB, 3 views)
Old 02-28-2021, 12:24 PM   #3
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
95 clusters are 95 only unfortunately. You’ll either need to do some re-wiring(unknown if that’s even possible going from obd1 to obd2), or find a 95 twin cam cluster
97 SL2, auto, 123K miles
Tags
fuel gauge, instrument cluster, saturn, sc2, wiring
Instrument Cluster Swap Chub S-Series Tech 5 12-01-2017 01:18 PM
Instrument Cluster swap PrestonIII S-Series Tech 10 11-03-2017 06:46 PM
Instrument Cluster Swap Saturnboy2002 S-Series Mods 3 06-06-2011 09:04 PM
instrument cluster swap 04Ion Ion Mods 8 04-05-2007 11:52 AM
instrument cluster swap 04Ion Ion Tech 1 04-02-2007 01:19 AM
