Old 11-28-2020, 06:13 PM   #1
moogoogypan
moogoogypan is a glorious beacon of lightmoogoogypan is a glorious beacon of lightmoogoogypan is a glorious beacon of lightmoogoogypan is a glorious beacon of lightmoogoogypan is a glorious beacon of light
Default Low voltage to headlights on right side
Hi,
Hit a dear three weeks ago, fixed the damage and then on the first day after repairs hit another dear. Damage both times was to the right, passenger, side. Replaced the headlight assembly including bulbs only to discover the lights glow dimly.
Checked connections and wires but no obvious issues. Some minor housing damage on wires to one of the lamps. As far as i can tell there is a single fuse for the headlights that has four pins and is located under the passenger dash.
Completely out of my element when it comes to electrical issues. Any guidance would be appreciated. was not able to find any answers in a forum search.
Thanks
moogoogypan is offline   Reply With Quote
Old 11-28-2020, 06:14 PM   #2
moogoogypan
Default Re: Low voltage to headlights on right side
Sorry car is a 2007 suturn vue 2.2L
Old 11-30-2020, 12:55 PM   #3
Bruce Rock
Bruce Rock is just really niceBruce Rock is just really niceBruce Rock is just really niceBruce Rock is just really nice
2000 SL2
2006 VUE 2.2L
Originally Posted by moogoogypan View Post
Hi,
This doesn't sound right. A single fuse with four pins? Sounds like a relay, not a fuse but according to Chilton both the 15 amp headlight fuse and the DRL relay are in the underhood fuse block.
"Completely out of my element when it comes to electrical issues".
That sounds correct.
"Any guidance would be appreciated". A library book on basic automotive wiring & Chilton Saturn Vue 2002-07 repair manual.
"was not able to find any answers in a forum search". Since you did a forum search I and I'm sure others here would be happy to help, just give us more to go on. All headlights dim or just right side? Same with high beams?
2002 Saturn. Replaced both headlights, now the drivers side Brights Wont work. AaronW S-Series Tech 1 05-27-2014 07:03 PM
ALL headlights are dim on one side of the car Procraftmike S-Series Tech 15 04-06-2013 01:25 AM
Voltage under the hood... No voltage in cabin? What to check? VolvoDude S-Series Tech 1 12-04-2010 03:06 PM
HELP drivers side high beam 0 voltage YourMainParadox Vue Tech 4 05-09-2009 03:15 PM
No high beam headlights right side 97 sl2 WJ33 S-Series Tech 3 12-24-2008 05:51 PM
