Old 12-27-2017, 05:07 PM   #1
MikeNW
MikeNW's Avatar
1997 SL
Default Wrapping up clutch and tranny project
Found a foreign car mech who will install the new pilot bearing and shaft. Explained the details, he understands.
For the following bolts, do you install: dry, lightly oiled, with never-seize, with threadlocker?
Flywheel to crankshaft
bell housing to engine
8mm bolts holding the tranny case sections together
When installing tranny pieces with gaskets, do you use any sealant or just bolt down (shift tower and end cover)
08 Burgman 400
Old 12-27-2017, 05:54 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Wrapping up clutch and tranny project
You lost me on the foreign car mechanic. Where was he from?
I put all those bolts and gaskets on dry.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 12-27-2017, 07:16 PM   #3
Flywheel to crankshaft __Locktite
bell housing to engine ___Locktite
8mm bolts holding the tranny case sections together___Lubed with ATF
When installing tranny pieces with gaskets, do you use any sealant or just bolt down (shift tower and end cover)__No sealant, install dry, there is only 1 for the selector tower.
Finding someone who will change that front bearing is good BUT that Locktite 620 is critical or the bearing assembly will walk out.
Old 12-28-2017, 11:02 AM   #4
MikeNW
MikeNW's Avatar
1997 SL
Yes sir, I explained the Loctite 620 and how the alum. case is fragile and how heat is needed to remove old shaft. He is familiar with the procedure.
Small shop, background in MB and Volvo and other over-engineered nightmares. He understands the concept with my Saturn
Thanks again.
08 Burgman 400
Old 12-28-2017, 12:50 PM   #5
That should cover it all then.
Old 12-31-2017, 12:18 PM   #6
MikeNW
MikeNW's Avatar
1997 SL
Next, the AXLE SEALS.
From Haynes, it looks like you carefully pry out old ones, tap in new ones, maybe with help of a tool from AAP? Or do you press them out and in.
Any sealant required?
The new ones are Timkens from RA.
Thanks.
08 Burgman 400
Old 12-31-2017, 01:49 PM   #7
Waiex191
Waiex191's Avatar
I had my case split when I replaced them. I drove them out, flipped the case over, drove the new one in. I made a tool to drive them using a roll of flashing. I used no sealant. There are pictures in my thread.
http://www.saturnfans.com/forums/sho...=230898&page=9
Bryan Cotton
Old 12-31-2017, 02:21 PM   #8
There is a snap ring holding in the left hand seal. Supposedly the FSM wants a very small thin bead of RTV in the corner of the seat. It is not required with quality seals but if metal to metal then do the RTV. Thin-no squeeze out thin.
Old 01-05-2018, 08:55 PM   #9
MikeNW
MikeNW's Avatar
1997 SL
PROGRESS....
Tapped out old, and installed new stronger Diff Pin. Old one was intact! 190,000 miles! A life without spinning wheels in snow, or jackrabbit starts etc.
Installed 2 axle seals. The only way I could seat the larger one was to put the case in the oven (at 175) and put the seal in the freezer. It seemed to take a tremendous amount of force to install. A really frustrating step. Yes I supported the back of the case when I set it.
Assembly tomorrow, high of 54 finally. Too cold in the garage now to think straight.
08 Burgman 400
Old 01-06-2018, 12:52 AM   #10
Did you take out the wire ring before removing the old one?
Old 01-06-2018, 11:35 AM   #11
MikeNW
MikeNW's Avatar
1997 SL
Yes, removed the large C ring before removing larger axle seal.
Had to tap around circumference of new seal, to seat the C ring.
08 Burgman 400
Old 01-06-2018, 11:53 AM   #12
Just checking as the seal can be extracted without removal if it is the round wire ring type. They are easy to install if the case is on the bench in summer time. National brand does fit relatively easy.
Vinyl wrapping my SL2 DrvLikHell S-Series General 28 06-16-2019 09:20 AM
Clutch & used Tranny Replacement Comments no Auto Zone clutch!! afptl S-Series General 2 02-22-2015 05:53 PM
2002 SC2 clutch project Lightfoot2002 S-Series General 1 09-21-2014 10:29 AM
Soon to be starting my tranny swap project BobtheTechguy S-Series Tech 2 03-05-2013 09:35 AM
New clutch kit and tranny, but still clicking noise from clutch unless pressed nulaw99 Vue Red Line 4 10-11-2012 11:41 AM
