Old 07-23-2014, 03:40 PM   #1
dragonem
dragonem is on a distinguished road
Default Does not stay running
Hello,
You all are Awesome. I got my car fixed and operational after coming here the first time. Now I have a different problem.
Trouble Code P0108 - Manifold Absolute Pressure/Barometric Pressure Circuit High Input.
Yesterday Car would not start, Giving car a little gas after it kicked would get it to start and then it would run at 3000 rpms and really rough. Checked MAP sensor to verify output. Looked good, I could not find the exact specs, closest I could find was for a 2.0l gm engine. Cleaned the seat for the Sensor. Put it back together. Now it starts, then dies. If I give it gas after it catches it will rev up then just die back out like its not getting any gas.
Please advise my options for what to look for or possible causes.
dragonem is offline   Reply With Quote
Old 07-23-2014, 03:53 PM   #2
Signmaster
Default Re: Does not stay running
From Richpin, one of the forums members here. This should give you everything you need to test the MAP.
http://www.youtube.com/watch?v=B8EVhFc5Yqw
If the MAP checks out double check for other codes.
Old 07-23-2014, 04:01 PM   #3
dragonem
Just as a note 2001 Saturn SL2 DOHC.
The only difference that I can see it that I started at 4.7V instead of 5 even. Everything else looks good, I got the same readings. Very informative though.
Tags
map sensor, p0108
2006 vue won't stay running achilano Vue General 2 01-19-2013 11:00 AM
SC1 Won't stay running alfasteve L-Series Tech 1 05-29-2012 03:18 PM
SC1 won't stay running alfasteve S-Series Tech 4 05-29-2012 09:08 AM
96 SL1 dwont stay running johnandjessica S-Series Tech 25 09-20-2010 11:23 PM
91 sc won't stay running medwards22 S-Series Tech 24 05-05-2009 02:52 PM
