Old 12-19-2010, 11:01 AM   #1
atomicsink
atomicsink is on a distinguished road
Default Headlights stay on - 2001 l300
My headlights stay on even when the car is off and the switch is in any of the positions. This is just the headlights themselves, nothing else stays on. I removed the DRL relay to no avail. The only way I can keep the batteries from draining is to remove the headlight fuses.
What can I do to narrow down the location of the fault? I tried jiggling the switch on the steering column but it didn't do anything.
Thank you very much for your time.
atomicsink is offline   Reply With Quote
Old 12-19-2010, 01:36 PM   #2
Default Re: Headlights stay on - 2001 l300
Pull the e-brake handle up and be sure the light switch is in the off or auto position and see. You may have to pull three BCM fuses to force a bcm reset; this may be the beginning of bcm failure so be aware of it. There are many threads about bcm failures and symptoms worth reading to have an idea of what may occur. Hopefully a reset fixes this for now.
Old 12-20-2010, 12:23 PM   #3
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Or, hopefully something simple like the stalk switch, which is a notoriously high failure item on L's.
Jerry N
Groucho Marx
L300 Wont Stay On blackberg L-Series Tech 4 04-19-2008 12:35 AM
2002 L300 headlights flash off then back on robertobates L-Series Tech 0 02-18-2008 07:20 PM
Tech Comm: Vehicle does not have timer for headlights to stay on… asrawlings@mchs Vue General 7 09-23-2006 09:03 PM
2001-SC2, water in both headlights greencoupe02 S-Series General 8 08-11-2006 04:27 PM
02 L300 fuel pump/car won't stay running problem MustangKatie L-Series Tech 2 08-11-2005 10:02 AM
