Old 01-04-2003, 01:59 PM   #1
pkuptrk
pkuptrk is on a distinguished road
Devil car wont stay running
After i got the 26 code i had to go to the store. On the way home it kept jerking and stalling.Whats is this?
pkuptrk is offline
Old 01-04-2003, 11:06 PM   #2
sattech
sattech is on a distinguished road
Default
Code 26 doesn't usually cause a driveability issue.
What year and model car do you have?
Oh never mind I found your other two posts on this. Like Ssicarman says check the search function for code 26 and you'll find a lot of info. But, it's probably not your stalling problem. Recheck your work, then check for vacuum leaks. Another possibility is that the hose to the map sensor- either at the sensor or at the back of the TBI unit- is old soft and may be pinching itself closed. Like Wolfman said, you also may want to check your coolant sensor operation
~ If it worked before you messed with it, it must be something you did ~
sattech is offline
Rough Idle Wont Stay Running DankAllumni S-Series Tech 9 08-07-2009 08:27 AM
my car wont stay running and idky scrapmedallord S-Series Tech 1 02-16-2009 11:54 AM
sl2 wont stay running, driving me nuts spare_change S-Series Tech 9 11-03-2008 09:30 AM
2000 sl2 dome lights stay on and car wont lock from outside bloody1 S-Series Tech 3 10-14-2005 04:20 PM
02 L300 fuel pump/car won't stay running problem MustangKatie L-Series Tech 2 08-11-2005 10:02 AM
