Old 12-27-2019, 04:40 AM   #1
aerial_22
aerial_22 has a spectacular aura aboutaerial_22 has a spectacular aura about
2007 VUE 2.2L
Wrench P0171 System Too Lean Bank 1
I have been getting an intermittent check engine light the past few weeks. With this condition I have noticed a drop in fuel mileage, as well as poor idle. I had it checked out and it threw the P0171 code for System Too Lean Bank 1.
I have replaced both the upstream and downstream O2 sensors within the past few years. My engine is at roughly 263,000 miles.
My thoughts are a bad MAP sensor, as I still have the original sensor.
Anyone have experience with this code and had to replace a MAP?
Thanks in advance!
aerial_22 is offline   Reply With Quote
Old 12-27-2019, 11:33 PM   #2
aerial_22
2007 VUE 2.2L
Default Re: P0171 System Too Lean Bank 1
Anyone? Could really use some advise on this issue. Thanks!
Old 12-28-2019, 02:37 PM   #3
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2006 ION-2 Sedan
The P0171 DTC is usually set when their is a vacuum leak. You can spray Brake cleaner or carburetor cleaner Around the intake manifold, the brake booster hose, the purge valve hose. test the purge valve by disconnecting the wire connector and the evaporative hose that leads to the back of the car and gas tank. with the wire connector removed the valve will default closed. with the engine idling their should not be any air sucking in the port you removed the evaporative hose from
Old 01-08-2020, 02:24 PM   #4
aerial_22
2007 VUE 2.2L
Thank you!
P0171-Fuel trim system Lean wpgtkd06 Ion Tech 6 05-28-2016 08:20 AM
Too lean bank? FASTIZCOOL L-Series Tech 0 12-25-2013 06:25 PM
2001 Saturn L100 -- P0171 lean on Bank 1 torsaturnL100 L-Series General 20 11-07-2013 09:30 PM
98 sl 5 speed Running Lean Bank 1 djsnaps12 S-Series Tech 10 03-08-2011 08:32 PM
System Too Lean P0171 & P0174 texan Vue Tech 11 01-09-2011 02:04 PM
