Old 12-17-2014, 11:09 AM   #1
Philsc2
Philsc2 is on a distinguished road
Default Outside door handle won't open door
Is there a link to a fix here? Thanks !
Philsc2 is offline   Reply With Quote
Old 12-17-2014, 12:43 PM   #2
Default Re: Outside door handle won't open door
Yes, there is.
Front door, rear door, year of car?
Probably going to involve removing the door panel, and seeing if something is disconnected or bent out of shape (and needs to be bent back)
Old 12-17-2014, 01:28 PM   #3
soliyou
soliyou is on a distinguished road
Thanks !!!
Exactly what i need right now
1998 - SL2 Plum - Auto - 120K miles recently aquired
soliyou is offline   Reply With Quote
Old 12-17-2014, 09:00 PM   #4
Philsc2
Grate ! Got r done . Ieven used a zip tie as a safety wire so it won't pull out again . Also greases up the window mechs and guides while i was there
For get all u thought u knew about cars. the inside door panel Don't touch it to get inside of the door.
2006 Vue rear door drivers side passenger door won't open. khelton79 Vue Tech 1 11-03-2014 03:48 PM
Door chime on when door open... billison Vue Tech 3 08-16-2008 07:39 PM
Door Chime Dings Whenever Door is Open Leadsled Coupe S-Series General 18 03-05-2007 03:30 AM
What's holding in the power door lock buttons in the door handle? Smokey S-Series Tech 2 09-22-2006 05:52 PM
Inside door panel removal? '93 SC2 -- specifically the door handle... benson500 S-Series Tech 5 12-06-2004 08:48 PM
