Old 10-17-2011, 03:49 PM   #1
mattachuz
mattachuz is on a distinguished road
mattachuz's Avatar
Default Successful Instrument Panel Upgrade (pics)
Well I posted around that I ordered 03-05 Cluster for my 2000 LS1, I got it in today, and for 23$ I got what I expected, a cluster with the dirtiest scratched up lens I've ever seen..
Uploaded with ImageShack.us
Not to worry though! I transplanted the lens from my 2000 LS2 cluster I bought at the junkyard to replace my original cluster that bulbs went out on me and I found it easier to just pop a whole cluster in rather then try to pull bulbs off a whole cluster and insert them into my original cluster.
When I pulled off the Lens on the 03-05 Cluster there was dirt on the gauges and dust so I had to clean that up. I put on my cleaner lens and installed it for a test run.
here are the results:
Before:
After:
off:
bulb check:
on:
Facelift @ 192k Miles lol. As stated on other threads it was a direct bolt in replacement with no wiring needed, you pull the 4 bolts on the trim, pull the trim out, and pull the 4 bolts on the cluster, tilt wheel down and pull cluster out.
Now for the help I request?! Im used to the self explanitory lights of the 2000 cluster, (change oil) (low traction) etc. Does anyone have the explanation sheet for the 2003-2005 Cluster, I figured most of them out but im confused on a few of them.
Thanks,
Matt
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Anahiem (disneyland): xxx
Tulare: o,(x-atleast 15)
Visalia: x
mattachuz is offline   Reply With Quote
Old 10-18-2011, 01:42 AM   #2
mattachuz
mattachuz's Avatar
Default Re: Successful Instrument Panel Upgrade (pics)
Nightfall hit:
I did some detailing to the lens and it looks great. I have to say the ODO readout on the newer clusters look brighter then the older ones?
EDIT: Looked at the lights more closely, found the change oil soon, trac, reduced power (v6) shift up (manual) the 2 check engine lights, DRL is still out but my relays modified so the DRL dont work
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Visalia: x
Looking for Instrument Panel Dumafach L-Series General 11 10-17-2011 10:42 AM
Who knows how to get the instrument panel out? ryanmcabee Vue General 2 12-19-2005 03:26 PM
Instrument Panel.. Help!! JoshM20 S-Series Tech 3 05-23-2005 04:30 AM
Instrument panel SaturnVue'03 Vue General 8 12-26-2003 11:22 PM
2nd gen instrument panel in 1st gen car? ProDarwin S-Series Mods 9 03-31-2003 07:35 PM
