Old 05-28-2011, 10:58 AM   #1
itsnotme1988
itsnotme1988 is on a distinguished road
itsnotme1988's Avatar
1993 SL1
Default Replace DCV14a with DCV11a
I put a '94 subframe in my '93 and have been in the process of changing over my A/C parts. Installed the new high pressure hose, condenser, and dryer today only to find that the DCV14a doesn't work with the '94 hose. As soon as I started to tighten the bolt it pulls the end end with the o-ring partially out.
My question is will the DCV11a bolt right up? Is the low pressure hose the same or will I need to change it too...I know the part number is different but they "look" the same in the pics but the refrigerant fitting looks different.
MP2 swapped '93 SL1, Sprint 2.0, SDA Dogbones, '94 Front Subframe, AMR Radiator
itsnotme1988 is offline   Reply With Quote
Old 05-28-2011, 11:24 AM   #2
Default Re: Replace DCV14a with DCV11a
Probably will have to change the hose to match the DCV11a compressor. The compressor mounting bracket to the engine is generic but the DOHC is different than the SOHC bracket.
Will a 96 MP7 replace a 99 MP7? Greg1 S-Series Tech 5 01-27-2011 01:02 AM
DCV11A vs DKV11A A/C compressors? billbled S-Series Tech 3 08-22-2010 08:53 AM
Tire replacement- replace one, replace them all? MRink Vue General 4 07-20-2010 09:56 AM
02 SL1 SHOC with oil in coolant: replace head vs replace engine - need advice surreyman S-Series Tech 3 05-02-2010 01:24 PM
EGR Valve: To Replace or Not to Replace? SL1Joe S-Series Tech 36 03-31-2008 09:56 PM
