Old 10-17-2009, 04:01 PM   #1
wallingclan
wallingclan is on a distinguished road
2004 ION-1 Sedan
Default As usual 2003 Horn problem
2003 V-6 Vue
No problems to speak of about 90,000 mi. Horn stuck today, pulled the fuse, horn stopped. The dreaded wrench light is on the dash.
1) I guess the horn is shot, though it still works, when I replace the fuse, but does not shut off. Can this be fixed?
2) Wrench light is the horn problem, How do I turn it off, and will it come back on again?
Thanks, really appreciate this.
wallingclan is offline   Reply With Quote
Old 10-17-2009, 08:02 PM   #2
VTchemist
VTchemist's Avatar
Default Re: As usual 2003 Horn problem
The problem may lie in the horn button/airbag assembly. The early VUEs had problems with the "flimsy" nature of the horn button. It's a plastic assembly that is built into the airbag unit.
If you have a voltmeter, you can check the relay as well as the horn.
If this checks out, I would not advise you to pull the airbag module unless you know what you are doing. If it goes off, while you are trying to work on the assembly, you could be seriously hurt.
I'd suggest you let a tech look at it. If it is the horn button/airbag assembly, it could be very pricey (to get a new one). A possible workaround is to see if you can find a 2002-03 airbag assembly from a parts yard.
Hope this helps...
2003 saturn vue horn problems megdog Vue General 13 11-17-2008 08:13 AM
2003 horn won't stop Pester Vue Tech 2 09-10-2008 01:13 PM
2003 Ion Horn Mach1 Ion General 8 09-30-2006 09:07 PM
Saturn Ion 2003 Horn going off tearinox Ion General 3 02-24-2006 09:48 AM
2003 Vue Horn problem jfvo Vue Tech 6 02-16-2005 11:17 AM
