Old 05-24-2022, 08:30 AM   #1
1993
1993 is on a distinguished road
Default Cant open door! 1992 SC
Something broke or fell off inside the door of my 1992 SC so i cant get the door open from the inside or outside! Anyone know of any tricks to get it open so i can take the door panel off and fix whatever is wrong?
1993 is offline   Reply With Quote
Old 05-24-2022, 04:18 PM   #2
Default Re: Cant open door! 1992 SC
There's some actuator rods inside the door that are attached to the inside and outside handles, and door lock. They are connected by plastic bits that break.
http://www.saturnfans.com/forums/sho...d.php?t=270087
To open the door, try removing the interior door handle. Should be able to pull on the rod using pliers to open the door. Hopefully, whatever broke is at this end. If it is at the other end, much more difficult.
This is for a 2nd gen, your 92 is probably similar. http://www.differentracing.com/tech_...doorpanel.html
Post 6 here has a diagram that shows all the interior bits
http://www.saturnfans.com/forums/sho...d.php?t=211161
1992 SC headlights stuck open.. 1993 S-Series Tech 14 05-11-2016 10:16 PM
Outside door handle won't open door Philsc2 S-Series Tech 3 12-17-2014 09:00 PM
2006 Vue rear door drivers side passenger door won't open. khelton79 Vue Tech 1 11-03-2014 03:48 PM
Door chime on when door open... billison Vue Tech 3 08-16-2008 07:39 PM
Door Chime Dings Whenever Door is Open Leadsled Coupe S-Series General 18 03-05-2007 03:30 AM
