Old 09-07-2021, 02:00 AM   #1
cuetip
cuetip is a splendid one to beholdcuetip is a splendid one to beholdcuetip is a splendid one to beholdcuetip is a splendid one to beholdcuetip is a splendid one to beholdcuetip is a splendid one to behold
1997 SW1
Default Manual Window Very Difficult to Roll Up and Down
I have manual crank windows, and my passenger side front window was kind of hard to roll up and down. So today I tried fixing it. With the window rolled all the way down, I sprayed some silicone lube in the channels where the glass travels up and down. This made the window even harder to roll up and down. It's so bad now that when I try rolling the windows up or down it feels like the crank is going to break off from the force needed to turn. The silicone lube trick worked great for the rear windows though. Any ideas?
cuetip is offline   Reply With Quote
Old 09-07-2021, 06:32 PM   #2
Default Re: Manual Window Very Difficult to Roll Up and Down
Don't force it, summat else will be damaged.
I would remove the door skin and get access to the regulator assembly, something is binding it up, or broken and no longer supporting the frame the glass rides up in.
hard, manual windows
98 SL1, manual window- will roll down but not up 98SatSl2 S-Series General 3 08-26-2016 03:29 PM
Manual Window won't roll up---HELP kevinss2001 S-Series Tech 20 12-30-2008 04:54 PM
98 SL2 manual window won't roll up danno_mn S-Series Tech 2 03-31-2008 11:29 AM
Manual window won't roll down or up sps SOHC S-Series Tech 3 06-18-2004 10:28 PM
Manual window hard to roll up! bkbucs S-Series Tech 7 03-08-2002 02:29 PM
