Old 01-23-2021, 01:25 AM   #1
seansaturn
seansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of light
seansaturn's Avatar
Default Rear Differential Replacement
Hi,
My rear differential was howling recently, it lasted around 3 minutes or so as I tried to limp it home. During this 3 minutes, I heard a bang. I went out to look and the differential cracked open on the rear drivers side and all of the fluid leaked out.
I have no idea why it was so sudden, I anticipated more warning. I recently changed the rear CV axle on the drivers side a week before, but I have trouble believing this any replacement CV axle could cause this. I thought if there was any problem with it, it would seperate at the inner or outer cv joint and not crack the differential housing! Maybe a coincidence?
Anyway, I have an entire differential assembly replacement ready and a bottle of Royal Purple Synchromax, so good to go, but I had a question about getting the drive shaft back in with regards to balancing. When I took it off in the summer, I marked the front and back, but of course, im replacing the entire back now lol. How do I go about re-installing it so I don't get a wobble? Does it matter that much? Any tips?
Hope this makes sense!
Thank you in advance
Saturn Vue 2007 AWD 3.5L V6 - Honda J35S1/GM L66 Engine
GinkoSolutions.com
seansaturn is offline   Reply With Quote
Old 01-29-2021, 11:36 PM   #2
seansaturn
seansaturn's Avatar
Default Re: Rear Differential Replacement
Looks like I'm going to put the drive shaft on and see if it gives a bad vibration.
If it does, I'll rotate it 90 degrees each time and see if that helps
GinkoSolutions.com
Old 02-09-2021, 02:16 AM   #3
zenors
zenors is on a distinguished road
Month ago I decided to change my HVAC system because old sytem were repaired million times. I decided to check info about electric furnace and after bought it https://www.thefurnaceoutlet.com/fur...-furnaces.html Hope it will work fine.
zenors is offline   Reply With Quote
Tags
differential, rear differential, saturn vue 2007, saturn vue awd
rear differential? Stuntman Kevin Vue Tech 19 11-06-2017 06:30 PM
AWD Rear Differential Removal oldmanina2005vu Vue General 1 08-17-2016 11:47 PM
Rear Differential brats Vue Tech 9 02-09-2016 07:29 AM
rear differential module bob3434dog Vue General 4 11-11-2008 01:00 PM
differential - buying and replacement questions plastic torpedo S-Series Tech 7 04-24-2007 05:34 AM
