Old 05-01-2011, 12:27 AM   #1
Ericth4
Ericth4 is on a distinguished road
Default Speedo and Tach issues
Hey all, I am a newbie saturn owner. With gas prices on the rise, my gas hog Dodge Ram is breaking the bank. I purchased a 92 SC from a friend of mine. He did an engine swap and it runs great. However, my speedo and tach do not work. Everything else works. Just not those. Here is what I have done so far. Checked the rev limiter. That tells me that the VSS is working. I changed the Passive restraint control module. The cruise doesn't come on when selected. Could that be an area to look in? Intrument panel? Trying to read through this Haynes manual, is like trying to put a 1000 piece puzzle together. I pretty good with puzzles but that has me frustrated more that any that I have done.
Another topic, The ECTS. The engine that he swapped was from a 96 SC2. How do Mod the sensors (since there is only 1 port) or should I just drill and tap another hole in the block?
Ericth4 is offline   Reply With Quote
Old 05-01-2011, 12:54 AM   #2
Default Re: Speedo and Tach issues
Drill and tap into the top outlet to the radiator. There is a flat spot right behind the hose on the head. How do you have the EGR valve connected to that engine and PCM? Which PCM is in it, the 96 or 92? Cluster will not work with the 96 PCM... PCM must match the car year and then you fiddle the engine to function. The major issue is the EGR. In your case it would be simpler to dredge up a 96 cluster and cruise system.
Old 05-01-2011, 01:46 AM   #3
'96 cluster won't even fit in the car. About the only way a complete '96 engine would run in a '92 car is with a '93 or '94 PCM. That's the only thing that will work with both the '96 crankshaft and the '92 cluster.
Old 05-01-2011, 02:08 AM   #4
It will take some serious cutting and pasting to get it to work - right. And a 93-94 and maybe a 95 PCM will cause other problems as you have to deal with an electric EGR which will require 94 CA PCM or a 95.
Old 05-01-2011, 08:15 PM   #5
Ericth4
When he installed it he left both EGRs in there. I know, I know...The one is connected to the PCM and zip tied to the engine. The other is connected to the engine but not operating. That is why I don't have an SES light. The car runs shifts and everything. That takes the EGR out of the equation for the the speedo and tach not working. I will pull the numbers off the engine and try to find out what year it is. It may not be out of the 96 SC2. At one point he said the engine was out of a 91 SC. I will double check.
Old 05-01-2011, 08:27 PM   #6
Above your left knee when sitting in the drivers seat is where the PCM is located. Look up and get both numbers off of it.
Lets do this the easy way, just take a picture of the ignition module and the 2 EGR valves.
Load the pix on a photo site and post the link back here with the http:// part deleted. Until you have 15 posts the system will not allow any links.
Speedo/ Tach light problem Warren Webb L-Series Tech 0 03-19-2011 11:27 PM
'02 Vue: PSCM, Tach, Speedo Problems GristleBear Vue Tech 1 09-13-2010 06:53 PM
Speedo/Tach issues Keeter S-Series Tech 1 10-11-2009 06:11 PM
has anyone swapped the speedo with the tach Tom S2 Astra General 8 06-27-2009 10:17 PM
No Tach, speedo or engine temp hammand S-Series Tech 4 09-05-2006 07:37 PM
