Old 10-11-2009, 05:49 PM   #1
Keeter
Keeter is on a distinguished road
Keeter's Avatar
1999 SL1
Default Speedo/Tach issues
Last night on my drive home on the interstate I had an occurance that is kinda boggling my brain. I had the cruise set a 70-71. Everything was working perfectly. Then the E-brake light came on, the tach needle dropped to zero, the speedo needle shuttered and dropped to zero. when they both zeroed out the e-brake light turned off and both neddles went back to where they were before. It did that about a dozen times in my 30 min ride back home. everything else stayed working. The gas gauge didn't move, nor did the temp gauge. The engine stayed running. It was like nothing else happened with the car. just the 2 needles dropping out and the e-brake light. The connections on the back of the gauge pod are tight.
Any thoughts?
That's my opinion,
Keeter
Keeter is offline   Reply With Quote
Old 10-11-2009, 06:11 PM   #2
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
Default Re: Speedo/Tach issues
Check your charging system, your battery and make sure the cables are free of corrosion.
Battery should be at 12.5 volts w/engine off, and around 14 volts w/engine running.
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
rickystarshine is offline   Reply With Quote
has anyone swapped the speedo with the tach Tom S2 Astra General 8 06-27-2009 10:17 PM
Speedo & Tach "Strange" behaviour? surprisinguy S-Series Tech 0 06-15-2009 11:04 AM
No Tach, speedo or engine temp hammand S-Series Tech 4 09-05-2006 07:37 PM
speedo maxwedge1964 Vue General 14 11-10-2005 04:52 PM
Speedo Issues dschrader Miscellaneous Tech 8 07-12-2004 08:53 AM
