Old 01-10-2010, 12:32 AM   #1
black_vue
black_vue is on a distinguished road
2004 VUE Red Line
Default Wheel Bearing Replacement
I believe I have a bad wheel bearing on my '04 Vue RL. It has 94K miles. Has anyone replaced this themselves? If so, how difficult was it? If you paid to have one replaced, I'd be interested to know how much it cost.
black_vue is offline   Reply With Quote
Old 01-10-2010, 12:41 AM   #2
redlineit
redlineit is on a distinguished road
redlineit's Avatar
Default Re: Wheel Bearing Replacement
heres my experience with it...read more in "Tire size question"
OK!! So I put my winter sets on finally and the noise was still there so I knew it was bearings... I could feel the pain of my wallet already, so heres the deal. I bring my RL in yesterday and the ******* comes out and tells me its $500 EACH SIDE for front bearings!!! I went nuts and was like give me my truck im outta here ill go to pepboys if I have to. So he brings me to the back and says my mistake, I overcharged you on labor... Its really $900. I said man your nuts thats not going to work so he says ok well I can throw in a 10% coupon to get it down to 800. I said ill tell ya what, we can do $700 cash and im out the door today. He agreed and started doing the job and leaves me in the waiting room for 4 HOURS! 10AM TO 2PM! Ok so he comes out 4 hours later and says listen, your axle melted into the wheel bearing so you will need an axle too which is "$600" extra. Now my total is up to $1300 plus wheel alignment for $100 plus inspection for $37 plus I had to get a rental for the day and the next. So I call today and he was "busy" so he call me back 6 hours later and says, "my technician left the key on and your battery died. I charged it but now the check engine light is on and I can't pass the inspection." ARE YOU KIDDING ME!!!!!!!!!
So he tells me he drove it 7 miles and you have to drive 9 for the light to go off??? I said WTF, if you drove 7 and you need to go 9 why would you go back and not do 2 more miles!?!? Im going in tomorrow morning to have a word with this wallet leech, I don't understand how an axle is $600. Even if thats with labor but there shouldn't be much since it was already apart for the bearings, $1400 is CRAZY. No wonder why saturn is going down.... I need my truck back so I guess im going to have to pay this BS but ill try and get him down to 1200 or something. UGHHHHHHH MERRY CHRISTMAS TO ME!
I ended up paying the 1400 to those *******s...never again
2004 Saturn Vue RL Black
redlineit is offline   Reply With Quote
Old 01-10-2010, 12:51 AM   #3
hein
hein will become famous soon enough
1995 SW2
1998 SW2
Here's a thread: http://www.saturnfans.com/forums/sho...d.php?t=131167
hein is offline   Reply With Quote
Old 01-10-2010, 10:45 AM   #4
black_vue
2004 VUE Red Line
The how-to in the link is perfect. I can handle that. I'll do it myself and avoid the stealership. Thanks!
Old 01-15-2010, 01:10 PM   #5
black_vue
2004 VUE Red Line
Wow, that was way more work than I expected. But, the job is done and it resolved the humming noise. Here in Minnesota, a lot of salt is used on the road and it corrodes all of the suspension. Nothing wanted to come apart, not the axles, and not the hubs. I finally pulled both steering knuckles and brought them into a shop with a serious hydraulic press. It still took the shop 15 minutes apiece with heat and the press to get the hubs out. I had sand the inside of the knuckles to remove all the rust and lube with anti-seize to install the new hubs. All in all, I spent 12 hours on this job!
Old 01-15-2010, 06:05 PM   #6
stbvue
stbvue is a jewel in the roughstbvue is a jewel in the roughstbvue is a jewel in the rough
stbvue's Avatar
It seems that all the Vue's have bearing problems. My 05 rear bearing went out not only 2 months after buying it. Luckily it was still under warranty then. Im beginning to think these cars were made with cheap parts. I hear of alot of bearing trouble with these Vues.
stbvue is offline   Reply With Quote
Old 05-21-2012, 03:53 PM   #7
blocknitup
blocknitup is on a distinguished road
I just replaced my passenger front wheel bearing and my tcs and abs light is on. Yes I plugged in the sensor, why is it doing it?
blocknitup is offline   Reply With Quote
Old 05-22-2012, 08:40 AM   #8
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Hello, and welcome to the forum!
As much as I hate to say this, it sounds like a faulty sensor or plug in the new hub assembly.
Try cleaning the terminals as well as you can. There could be some corrosion that worked loose when the old one was unplugged, causing a weak connection.
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
RedGeminiPA is offline   Reply With Quote
Old 11-29-2016, 07:42 AM   #9
bengalsgrowl
bengalsgrowl is on a distinguished road
2006 VUE 3.0L
Thumbs Up Re: Wheel Bearing Replacement
I know this is an old thread, but i wanna say thanks for all the info,
I just replaced the wheel bearing hub on the passenger side of my 2006 Saturn Vue.
First I wanna say tried for 2 days, a total of about 8 hrs banging on the hub to try and free it.... lost cause... torches, PB Blaster, homemade rust killer/lube (transmission fluid and acetone, formula i got from watching a youtube video). Still wouldn't come free.. I can't stress enough how frustrating this was. I recommend giving this a try but don't get sucked into trying to save time by using a hammer, if it's not free after an hr or two you probably shouldn't waste anymore time.
Finally i took the whole knuckle off, which only took about 10 minutes. 2 tap bolts on upper arm (remove nuts with 18mm socket then tap bolts out), nut at lower arm steering knuckle (18mm socket, mine had a cotter pin that snapped. less than a dollar to replace), nut under tie rod ball joint (18mm socket). Also i noticed there are a few different axel nut sizes mentioned throughout forums, mine was a 33mm on my 2006. (sooo easy, wish i did this to begin with)
Took the whole assembly to work and used a hydraulic press to free the hub.
This took 5 minutes, and so much pressure it made it very clear after that there wasn't a chance that i could get it free with a hammer. In my case taking the whole thing off is definitely the easier route, especially being from Ohio, the hub was very corroded and seized. I hear you can take the assembly to an auto parts store to press it out, or you can give it a go hitting the backside with a hammer now that it is off.
Good luck to all who take on this project, i think it can be very easy or extremely time consuming, i found out the hard way.
bengalsgrowl is offline   Reply With Quote
Old 11-30-2016, 12:34 PM   #10
04RDLN
04RDLN is on a distinguished road
04RDLN's Avatar
2004 VUE Red Line
https://www.am-autoparts.com/product...l?m=952&y=2004
These are the new Hub/Bearing assemblies I used on my Redline. I suggest also getting new knuckles. Save yourself the headache of trying to get the old ones out, unless you have a hydraulic press.
http://www.cardomain.com/ride/2241358
04RDLN is offline   Reply With Quote
Old 12-03-2016, 09:43 AM   #11
Vue6
Vue6's Avatar
2006 VUE Red Line
...If the weather is not cooperating outside and you don't feel like dealing with salt corrosion, it cost me about 100 bucks to have a wb done, and it took the place about a 1/2 hr to an hr to do with an air chisel and torch, just my .02, DC
Old 12-03-2016, 10:00 AM   #12
billysvue
Left coast and nonRustBElt VUe bearings almost fall out after unbolting.
NO hyd press needed( maybe a puller) but that might not be needed, either.
I've done all corners(+2) and needed the puller on just one.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 07-15-2021, 08:22 PM   #13
Northerner
Northerner is on a distinguished road
The bearings on these (I've owned 2 2004, 4 cylinder manual trans's) were atrocious.
Unacceptably poorly made.
And now I have another one (if not both) in front that I think needs to be replaced again. Bollocks.
Northerner is offline   Reply With Quote
Old 07-16-2021, 05:13 PM   #14
waiter21
2003 VUE 2.2L
How many miles on the bearings??.. I put new ones on mine three years ago, about 60k miles ago
Old 08-15-2021, 09:18 AM   #15
Cavell
Easy to do.
File Type: jpg 6E01C8A7-97D5-4B99-8AC4-C079EB52AD31.jpg (62.2 KB, 8 views)
Old 08-15-2021, 04:27 PM   #16
Northerner
Originally Posted by Cavell View Post
Easy to do.
Has that Vue spent its entire life in MN? Hard to believe it was that easy from what I have read around this forum.
(I've been on the East Side of St. Paul my whole life).
Old 08-16-2021, 10:42 AM   #17
Cavell
Had it for 1 yr. the bearing just fell out when unbolted. 1st time I’ve seen that. I’ve done a dozen. It is a hicks brand bearing. Did not look that old. Very little rust.
Rear Wheel Hub/Bearing Replacement uhlemd Vue Tech 23 10-31-2020 03:39 PM
2003 L200 Wheel Bearing replacement !help! Vulcan L-Series Tech 5 05-14-2014 04:08 PM
Rear wheel bearing replacement elitemarksman S-Series Tech 6 12-10-2009 10:28 PM
2002 SL Wheel Bearing Replacement Skydmark1 S-Series Tech 19 05-17-2007 08:04 PM
front wheel bearing replacement help.. 1993 S-Series Tech 2 06-23-2006 10:37 PM
