Old 06-17-2021, 04:44 PM   #1
afskwarek
afskwarek is a jewel in the roughafskwarek is a jewel in the roughafskwarek is a jewel in the rough
Default AC Compressor Rattle - With Video
Greetings
So my AC compressor has as rattle. It noticeably rattles often while running even when ac is off. It rattles fairly consistently when during higher revs and when the ac is on (obviously). Been going on for the past few years. Been getting more frequent. All I'm wondering is, is it really that big of a deal? Can I replace the pulley without pulling the compressor? Cause I rather not deal with the hassle of evacuating and recharging entire system if I don't have to.
Thanks!
Compressor rattle on video:
https://youtu.be/D9Hn_BzdSk0
afskwarek is offline   Reply With Quote
Old 06-17-2021, 06:15 PM   #2
afskwarek
Default Re: AC Compressor Rattle - With Video
Minor correction of minor importance. It only really rattles when the ac is on. Only rattle when a is off is when only high revving. So it's clearly the compressor.
Old 06-17-2021, 06:18 PM   #3
cujoe_da_man
cujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nice
cujoe_da_man's Avatar
2000 SL1
While I was diagnosing my system, I watched a video of a guy removing the clutch off his A/C (on a Mustang) and his clutch plate was doing a similar thing. I think you can just replace the clutch plate and be fine as long as the magnet is pulling the plate in with no issues, though finding one might be a chore...
The plate unbolts from that center bolt and shoooould slide off, might have to use a small pry bar to wiggle it around a bit, but it should just come right off (it's the rest of the stuff that can be hard to come off). If worse comes to worse, you can unbolt the whole compressor from its cradle without taking the hoses off and get a tool to remove it, most auto parts stores rent them out.
Be thankful these ones are at the top of the engine.
Check out my current SL1!
http://www.saturnfans.com/forums/showthread.php?t=268456
cujoe_da_man is offline   Reply With Quote
Old 06-18-2021, 01:16 AM   #4
There should be three rivets, buttons to anyone unfamiliar with vehicle ac compressors. The three rivets hold three straps. Each strap is riveted to the compressor clutch plate. In technical terms, the three straps connecting the compressor hub to the clutch plate may be described as a flexure configuration. This allows the clutch plate to move inwards towards the pulley for engagement or away in normal position. The .012-0.018 inch air gap between clutch plate and pulley face allows the clutch to rest, disengaged from the idler pulley. When the clutch coil is powered up, the magnetic field generated attracts the clutch plate to engage the idler pulley resulting in compressor operation. The rivet is either worn down or broken, leaving one strap loose and making noise. The clutch plate/hub assembly should be replaced. If damage occurred to the idler pulley face from the loose strap, the idler pulley should be replaced too.
Clutch plate replacement is mostly a diy repair to anyone with skills. Repair shops and dealers prefer to replace the entire compressor along with a new drier.
Old 06-18-2021, 04:26 PM   #5
boomerB5
boomerB5 is on a distinguished road
1999 SL1
2005 RELAY-2
For many cars it is supposedly a pretty easy task to remove the clutch plate. Many require no special tools. Some require tools that most auto parts stores will lend out. But I just picked up a compressor from the junkyard that uses the same sort of clutch shown in your video. It requires special tools that are almost impossible to find. Literally no store seems to stock them. You might be able to find them on ebay if you are lucky. Its the reason I still don't have AC in my 99 Sl1.
boomerB5 is offline   Reply With Quote
AC compressor oil leak = compressor seize? 2003vue Vue Tech 10 01-24-2013 05:54 PM
A/C Compressor Question: Is my compressor bad? TIMSPEED S-Series Tech 8 04-18-2009 12:03 AM
Help - rattle & no power (video) charger500 S-Series Tech 13 01-24-2009 06:38 PM
1994 SL2, Cold Rattle/Warm No Rattle Slight Hesitation acidburn_335 S-Series General 0 09-02-2004 08:34 AM
video help rehm70 Ion General 4 10-07-2003 02:22 PM
