Old 08-22-2009, 03:32 PM   #1
Growser
Growser is on a distinguished road
Growser's Avatar
Default Fuel Rail/Fuel Filter Question
1993 SC2, Auto transmission. Finishing up my first engine R/R, had to detach the fuel lines to the fuel rail, and took advantage of the open space and replaced the fuel filter. I know there is a tiny rubber washer that goes on the line going to the fuel rail. But on the 2nd line coming in from the fuel filter that attaches to the pressure regulator, I did not see a washer. Is there suppose to be one?
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Growser is offline   Reply With Quote
Old 08-22-2009, 11:18 PM   #2
Default Re: Fuel Rail/Fuel Filter Question
There is an o-ring between the regulator and the rail and a second o-ring on the bottom where the metal fuel line attaches. The flexible return line fitting has a seal ring inside of it also.
Old 08-23-2009, 12:02 AM   #3
Growser
Growser's Avatar
Thanks OldNuc. Is the o-ring on the bottom where the fuel line attaches to the regulator the same size as the one where the other fuel line attaches to the end of the fuel rail? That one stayed attached but I lost the other.
Old 08-23-2009, 01:25 AM   #4
Don't rightly know. I just wander over to the big box of Buna-N o-rings and find one that fits. The ones from the plumbing/hardware shop tend to be SBR and it does not play well with fuel but I suspect that you could get away with it. It just fits over the fitting on the bottom with minimal stretch. There is also minimal pressure in that return line.
swapped in new injectors, no fuel to fuel rail! DJboozeAlot S-Series Tech 6 06-05-2009 04:10 PM
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? 2003MercMaraude S-Series Tech 2 10-17-2008 07:29 AM
What happens if you kink/bend a fuel line during fuel filter installation? Dingo Warrior S-Series Tech 4 05-31-2008 10:43 PM
1998 Fuel Filter - (Fuel line retainers) Jeffsimpson S-Series Tech 3 01-30-2008 09:42 PM
Size of Fuel Pressure connector on fuel rail bc3tech Ion Tech 0 09-08-2006 11:15 AM
