Old 04-14-2007, 08:12 PM   #1
KevinVarnes
KevinVarnes has a spectacular aura aboutKevinVarnes has a spectacular aura about
1995 SW2
Default TPS Connector
Hello,
Wife's car is a 2000 SL1. It's had an occasional high idle problem for a while now. While driving the idle will sometimes creep up to 2.5k RPM (even seen it go as high as 3k RPM). I had to drive the car the other day and found it extremely annoying. I've replaced the Coolant Temp Sensor. A while back I replaced the IAC valve (common failure on Fords which is what I've been working on for the past few years). I was playing around with it today and I can change the idle speed by wiggling the TPS connector. Voltage on the TPS seemed okay with about .58V at idle and progressed smoothly up to 4.5V at WOT. Would this be a problem with the connector itself or the TPS? I can't seem to find anyone that sells the TPS connector, or maybe I haven't looked hard enough. I've read through enough older posts where people have had good luck with the "wiggle test" and replacing the TPS, but this just doesn't seem right to me.
'85 Ford LTD Squire
'89 Cougar XR-7 5 Speed
'95 T-Bird SC 5 Speed
'97 T-Bird LX
'91 Crown Vic P72 351W
'98 Saturn SW2 5 Speed (wife's car)
KevinVarnes is offline   Reply With Quote
Old 04-14-2007, 08:56 PM   #2
kthane
kthane is on a distinguished road
1999 SL1
Default Re: TPS Connector
look anything like this
http://www.speedscenewiring.com/v-we...7728ca07c0070e
I bought one from them with pigtails. These are most definitely hard to find.
kthane is offline   Reply With Quote
Old 04-14-2007, 09:06 PM   #3
KevinVarnes
1995 SW2
That certainly looks like it. Have you used one? I am assuming it was used as a MAP sensor connector for another application? That is a great site. I'll have to bookmark that one.
'85 Ford LTD Squire
'97 T-Bird LX
Old 04-14-2007, 09:17 PM   #4
kthane
1999 SL1
Yeah. I bought one from them. That exact one. I had the same problem. The contacts to TPS were not making good connection. Consequently I sometime had a climbing idle. I replaced my TPS twice before figuring out it was bad connection. I also bought the green MAP sensor connector when I broke the locking tab off. I just replaced the shell and not the terminals on that. Great place to buy a replacement connector for your GM/Saturn.
Old 04-14-2007, 10:45 PM   #5
KevinVarnes
1995 SW2
Thanks kthane. I'll order one up. I appreciate the link and the quick replies.
'85 Ford LTD Squire
'97 T-Bird LX
tps connector builtsl1tough S-Series Tech 3 12-02-2009 01:25 PM
Tps electralux S-Series Tech 7 08-12-2009 06:38 PM
TPS CE light, replaced TPS, light came back! DJboozeAlot S-Series Tech 6 07-13-2009 02:18 AM
Tps devolic S-Series Tech 5 07-25-2007 10:21 AM
Tps? quiksc2 S-Series Tech 3 06-22-2007 03:17 PM
