Old 03-29-2005, 02:16 AM   #1
Chingon
Chingon is on a distinguished road
1993 SC2
Default Changed spark plugs and wires, look at old plugs (pics)
I went to Autozone and picked up some NGK V-power (or whatever they're called) plugs and some wires...
When I took out the first plug, the one with the shortest wire/farthest right, it was clean/dry but it had some white stuff on it, corrosion I guess. Then I do the rest and I'm like, WTF!?!?!
Here's a pic of the plugs in the order you would see them if you popped the hood...
Here are close ups...first pic are the 2 left side plugs, then a pic of the 2 right side plugs
The plug on the very right was nice and clean and dry as I said, the next one was nasty, the 3rd one from the right was clean on the threads, but the hex part was sludge and the 4th one(way left plug) was just soaked.
1993 SC2 (The beater)
2001 GMC Sierra V8/nitrous/stall/tuned
Chingon is offline
Old 03-29-2005, 02:24 AM   #2
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default Re: Changed spark plugs and wires, look at old plugs (pics)
bad valve cover gasket
M.Nguyen is offline
Old 03-29-2005, 02:28 AM   #3
Chingon
1993 SC2
Is that difficult to replace? How much for parts?
Chingon is offline
Old 03-29-2005, 02:47 AM   #4
raysride
raysride is on a distinguished road
raysride's Avatar
1996 SL1
Good news is the burn on your old plugs looks good
1996 SL 1
raysride is offline
Old 03-29-2005, 04:27 AM   #5
M.Nguyen
M.Nguyen's Avatar
1993 SL2
Hardly. do it according to Wolfman's instructions and you're good to go. But if i may sugguest, please get a torque wrench. It will definately save you money in the end (drilling, tapping, tapering, helicoil...stuff like that.)
M.Nguyen is offline
Old 03-29-2005, 08:15 AM   #6
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
The good news is, the engine looks great! Just some oil dribbling from the outside to inside.
alleninpa is offline
Old 03-29-2005, 10:05 AM   #7
the_new_raceman
the_new_raceman is on a distinguished road
the_new_raceman's Avatar
I just did a valve cover gasket on mine and no its not very hard. Had it off, cleaned, gasketted, sealed, and torqued in like 40 mins.
the_new_raceman is offline
Old 03-29-2005, 01:42 PM   #8
Qlara
Qlara's Avatar
Just make sure you borrow/buy a in-lb Torque Wrench for your Valve Cover job. Also you need a Star-shape? tool (T## forgot the size) to loose the cover bolts.
Use OEM cover gasket (actually it's just a pre-shaped RTV) and read Wolfman's How-To instructions.
Qlara is offline
Old 03-29-2005, 03:28 PM   #9
ry92sc
ry92sc is on a distinguished road
ry92sc's Avatar
1992 SC
my 96 uses 10 mm bolts to hold down the cover and the bolts wont release from the cover itself its really weird. I guess models varry
ry92sc is offline
Old 03-29-2005, 03:46 PM   #10
Qlara
Qlara's Avatar
Good info, though I wonder what model year Chingon has.
I believe the 10mm bolts only applied to BLACK plastic composite DOHC valve cover '96+ year?
Qlara is offline
Old 03-30-2005, 03:02 AM   #11
Chingon
1993 SC2
Read sig, it's a '93. Does anyone have the part number to this gasket? Thanks in advance.
Chingon is offline
Old 03-30-2005, 03:27 AM   #12
Chingon
1993 SC2
I'm not sure if I understand. That article is to change the camcover gasket, but the article says my car has the aluminum cover which requires no gasket? What exactly am I changing? Is it just to clean out the cover?
Chingon is offline
Old 03-30-2005, 03:42 AM   #13
Chingon
1993 SC2
Nevermind, I figured it out.
Chingon is offline
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 08:29 AM
Dealer pricing on spark plug wires and spark plugs. KeithR S-Series General 25 05-20-2011 12:52 AM
Just changed my spark plugs. mgordon1100 S-Series General 13 10-11-2009 10:50 PM
2.2L - spark plugs changed Tom92SCm Vue Tech 0 07-29-2008 11:50 PM
Changed Plugs and Wires now rough idle stinka S-Series Tech 8 08-17-2006 08:48 AM
