Old 09-13-2021, 11:29 AM   #1
Im512blue
Im512blue is on a distinguished road
Dizzy 2005 Saturn Vue 4 cylinder
Im having issues starting my saturn, my car hasnt started since jan of this year. ive tried everything. the fuel pump turns on but car not getting any gas. Ive checked fuel pump sensor its fine. Im thinking maybe its the security system couldve shut gas off...Ive checked the fuel lines changed fuel filter, gas isnt reaching my injectors or something. I really hate to sell my car for junk when it could be something as simple as a reset button. I dont know where to look, im hoping to find some real answers here. when the problem first started I had to charge my battery, so I took it out to charge it. Its holding charge all these months, windows work inside light comes on etc. Im thinking because I disconnected the battery it triggered some sercurity code with in, I had hooked to code reader and the codes said 4th cylinder misfiring, faulty fuel injectors, I changed my plugs and coil pack, and had my injectors tested. was told my injectors are working fine. now its not showing any codes at all. Im thinking reason for this it hasnt run. i dont know what else to do. Help please
Im512blue is offline   Reply With Quote
Old 09-13-2021, 12:45 PM   #2
Default Re: 2005 Saturn Vue 4 cylinder
GM uses Passlock as their factory security system. Four security inductor modes; always ON, OFF, blinking when remotes are used to Lock doors, and flashing quickly when a theft attempt occurs - Passlock disables injector operation to prevent driving.
Which security mode indication is your Vue showing? Remotes enable/disable security by pressing Lock or Unlock. When ignition is turned on, is the security indicator (car symbol with large padlock) on, off, blinking or flashing?
2005 Saturn Vue Evap/Cylinder Error Codes LinuxEngi Vue General 3 06-13-2016 02:45 PM
Won’t start and won’t run intermittently 2005 Vue 4 cylinder 5 speed ddjjsea Vue Tech 5 07-07-2013 01:55 PM
2005 Slave Cylinder is Toast SLAPSHOT Vue Tech 24 02-08-2013 06:06 PM
2005 Saturn Ion3, Is my Ignition Lock Cylinder bad? CatfishJohn Ion General 13 02-16-2009 11:03 PM
2005 4 Cylinder Oil Filter / Plug locations? maxgrant Vue Tech 1 09-18-2005 06:01 PM
