Old 08-30-2019, 11:12 AM   #1
trottida
trottida's Avatar
Default 2001 SL1 BCM into 2000 SL1
Our 2001 SL1 MT (10th anniversary clone,430K km) is end of life based on undercarriage rot through and I think I've found a 2000 SL1 MT that is solid but has needs polymer panels and such replaced. I'm thinking of using the 01 for parts as it is the same colour. I'll move over all the 10th Anniversary goodies too. The end result will be a sunroof upgrade and 280K km less mileage.
The 2000 is only optioned with a sunroof if you can believe it. No cruise, no air no other options. I'd like to move the cruise control module over and avoid the BCM programming business with the dealer at $120.
Will the 2001 BCM be compatible with the 2000?
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 08-30-2019, 01:19 PM   #2
Default Re: 2001 SL1 BCM into 2000 SL1
If I'm not mistaken, mileage and VIN are in the bcm so you're speedo will probably increment to the higher mileage. Registration might be a problem as the windshield and other locations of VIN won't match bcm VIN. GM should be able to answer questions whether or not VIN can be altered on BCMs.
Old 08-30-2019, 02:12 PM   #3
trottida
trottida's Avatar
My 99 SL2 VIN in the PCM doesn't match what's plated on the car. This hasn't created any issues for me. If you recall I moved and engine over from a parts car including the wiring harness and the PCM (auto to manual conversion). The work was done before it was registered.
I hadn't thought of the mileage thing; I don't see that as an issue either as I don't intend to ever sell the car. Drive it till it's done!
Good points though!
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 08-30-2019, 03:29 PM   #4
The VIN can be rewritten by reflashing the entire mess. Dealer will want a hour of labor and probably not know how to do it right the first time.
Old 09-03-2019, 08:03 AM   #5
trottida
trottida's Avatar
... and what about my original question?
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 09-03-2019, 08:10 AM   #6
The 2 connector BCMs are compatible and the 3 connector BCMs are compatible but a connector count mismatch is likely incompatible without moving the wiring harness as well to get the connector match. Security relearn will marry it all up as long as you only move a single secured device at a time between security relearns.
Old 09-03-2019, 08:27 AM   #7
trottida
trottida's Avatar
So if the wire harness to BCM connectors match then it's a go; if they do not match then it's a no go unless the wire harness is moved over. Correct? Anybody know if they changed from 2000 to 2001?
All I'm looking to do is to move over the BCM from the 2001 to enable cruise control on the prospective 2000. So only a single secured device is to be moved over.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 09-03-2019, 09:17 AM   #8
According to AllData & GM's ESI they both have 3 connector BCM's, but the '01 has 2 brown and a blue while the '00 has a blue, purple and brown.
Seems easier to just have a Tech II or equivalent on hand. It's simpler than swapping BCM's and if the remarry process goes wrong you'll have to have the Tech II to fix it anyway.
Old 09-03-2019, 09:44 AM   #9
You must have the wiring diagram and the build date of the 00 model is critical. If the connector wiring is different then they are incompatible.
Tags
bcm, cruise control
Looking for opinions on buying 2000/SC1 2001/SL1 m715 S-Series General 4 03-10-2009 08:29 PM
Will a Taillight Lens from a 2001 SL fit a 2000 SW??? BarnOwl S-Series Tech 2 03-27-2007 06:25 PM
Anyone with 2000-2001 Twincam norm97SC2 S-Series General 17 06-07-2005 01:13 PM
2000 STB on a 2001 juggaloenforcer S-Series Tech 2 12-19-2004 05:16 AM
2000/2001 OEM AM/FM/CD/Cassette YELO_SC2 Classifieds 0 07-03-2001 09:42 AM
