Old 04-11-2018, 08:32 PM   #1
Semi-auto SL2
Semi-auto SL2 is on a distinguished road
Dizzy Brake sound.
Hello everyone, I drive a 96 Saturn SL2 with 109k miles on it. I recently purchased this vehicle about a month ago from the original owner. The car was garaged for a while and kept very clean and well maintained. Recently I have had a squeaking break noise while driving forward the sound begins from the start in first gear and continues until about third gear. The faster I go the more faint it becomes. Sometimes when I hit a bump or rough patch of road the squeak intensifies. The sound goes away when the brakes are applied. I have yet to take a look myself at the pads as I am seeking advice before doing any investigating. If y'all have any suggestions I would greatly appreciate it. All brakes are rotors no drums.
Sincerely, Semi-automatic SL2
Semi-auto SL2 is offline   Reply With Quote
Old 04-11-2018, 09:28 PM   #2
lectric95
lectric95 is on a distinguished road
Default Re: Brake sound.
Possibly just worn pads, the tattle will ride the rotor until you press the brakes, it will also get quieter as speed increases.
lectric95 is offline   Reply With Quote
Old 04-13-2018, 12:22 PM   #3
2NDSOUT
2NDSOUT's Avatar
1999 SL
Could be worn pads, warped rotors...Caliper Pin sticking causing pad drag on the rotors.... where is the sound coming from, Left Wheel or Right Wheel?
Usually when Pads get worn down; there is what is known as a "Squeaker Plate" that will tell you if they are worn down to the point of needing replacement.
The Pins are 14 MM for top and bottom, the Caliper Bridge is held in with 18MM bolts to the Wheel Hub.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Tags
brakes, breaks, noise, noises, sseries
Resonating Brake Sound Nkingram Aura General 2 01-25-2017 05:48 PM
brake issue? terrible sound solarcar_sc1 S-Series Tech 1 11-03-2013 09:20 PM
Brake Knocking Sound?? Saturn9 L-Series Tech 1 06-04-2013 11:42 AM
Brake Pedal Sound Berry34 Aura General 1 09-15-2007 10:41 PM
Bouncing Spring Sound whenever I brake?!?! jlk51496 L-Series General 1 05-21-2006 08:43 PM
