Old 11-30-2017, 10:33 PM   #1
Chub
Chub is just really niceChub is just really niceChub is just really niceChub is just really nice
Chub's Avatar
Default Instrument Cluster Swap
I've done some looking but haven't been able to find the answer. Does anyone know if a 1996 instrument cluster will work in a 1995? I accidentally shorted out the speedo on my '95 cluster (doesn't register speed anymore but VSS is verified working) and have a '96 one readily available. Just wanted to see if anybody knew before I hacked my two clusters together since the 1995 one has a whole bunch of mods on it that I don't want to do again. Thanks.
1995 SC2: Back on the road again after my second engine rebuild in two years.
Chub is offline   Reply With Quote
Old 11-30-2017, 11:17 PM   #2
Default Re: Instrument Cluster Swap
It might but do not know for sure. If you have drawings check connector compatibility. If you don't I can check in the AM.
Old 12-01-2017, 12:19 AM   #3
Chub
Chub's Avatar
According to the parts swap interchanges it says that they would swap, but the '95 model certainly has been found to have some special parts. I don't have a drawing for the '96. I have one for the '95 and a '98 (way too new). The 95 / 96 clusters have a ribbon connector just for the speedometer (which I accidentally tore on mine when adding LEDs) on the back of the cluster where a '97 that I took apart did not have this connection. I am willing to bet the 96 will work but I'd rather not fry the whole cluster if I can avoid it. Thanks for the help.
Old 12-01-2017, 01:08 AM   #4
'95-'96 pinout & connector identical. '97-'99 the connector is still the same, but the pinout is different.
Old 12-01-2017, 01:25 AM   #5
Chub
Chub's Avatar
Good to know. Thanks for the info. I'll give it a try!
Old 12-01-2017, 01:18 PM   #6
95SC2 and all 96 should swap as the 95 SC2 has the gen-2 interior and cluster. The 96 is the oddball in the gen 2 as the 97-99 all do swap fine. So the guess last night was the 95SC2 and 96 were identical parts.
Instrument Cluster swap PrestonIII S-Series Tech 10 11-03-2017 06:46 PM
Instrument Cluster Swap - Compatibility SW2 Driver S-Series General 23 09-09-2015 06:29 PM
Instrument Cluster Swap Saturnboy2002 S-Series Mods 3 06-06-2011 09:04 PM
instrument cluster swap 04Ion Ion Mods 8 04-05-2007 11:52 AM
instrument cluster swap 04Ion Ion Tech 1 04-02-2007 01:19 AM
