Old 05-02-2015, 02:30 AM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Dizzy with ac on ... engine fan does not come on
1997 sl2 and 1998 sc2
Both the cars have same prob.
Engine cooling fan does not come on...
I checked relay and fuses a.. They are all ok..
What else should I check...
I read somewhere if there is not enough refrigerent
Fan would not come on.. Is that true? How do I check its level?
vikasevan is offline   Reply With Quote
Old 05-02-2015, 09:05 AM   #2
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
Default Re: with ac on ... engine fan does not come on
Are you trying to troubleshoot a fan issue, or an AC issue here?
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
wi111y is offline   Reply With Quote
Old 05-02-2015, 09:13 AM   #3
Quick check is to shove a jumper wire between pins 30 and 87 of the radiator fan relay in the UHJB. If it turns on then it works fine.
The A/C button doesn't turn on A/C, it asks the PCM to turn it on. The light stays on to let you know you've already asked for it, not to let you know A/C is on.
Old 05-02-2015, 03:17 PM   #4
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Is there any image I can check to find out which are 30 and 87 pin and what do u mean by uhjb ?
and relay has to be exact same numbers as it was originally in the car ? or you can replace relay with other years and models from Saturn?
Old 05-02-2015, 05:12 PM   #5
Under Hood Junction Box
Every relay has a diagram on the side and each pin is numbered on the bottom/pin side.
Pretty sure '91-'95 is all 4pin relay's that don't totally swap with '96-'02 5pin relays (even when the '96-'02 use's a 4pin they're different). Most GM's use the same fuse's and relays in the '90's so finding more in a junkyard should be easy.
Old 05-02-2015, 05:13 PM   #6
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
air conditioner
Old 05-02-2015, 05:20 PM   #7
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Thanks I will look in to it if fan is working but I think fan does not have problem beccause it does not overheat so at idle when it reaches required temp it does come on ...
Engine lack of power with DTCs P0011, P0014, P000A, P000B, P0012, P0015 or engine rat Tom S2 Astra Tech 45 07-28-2016 08:33 AM
swapping a 1997 DOHC engine for a 1998 SOHC engine jlannigan S-Series General 10 10-22-2011 05:36 PM
has any1 thrown a timing chain and NOT had engine damage on SOHC sl1 type engine? MacExperts S-Series Tech 14 09-21-2006 06:04 PM
Rough engine start, High Idling, and Cold running engine(?)... brownmota S-Series General 10 04-30-2006 09:50 AM
Ignition Module / Engine Coolant Sensor Prob? Service Engine Light, Rough Performins Brendo613 S-Series Tech 14 10-19-2005 07:12 AM
