Old 04-16-2015, 02:55 AM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Default When airbags deploy clockspring needs be changed?
A friend of mine crashed his 2001 Saturn sl2 ..both airbags deployed.
That yellow connector that connects airbag on back burned and got fused with airbag....we had to break it apart...and we found a donor yellow connector from junkyard along with airbag.
Replace yellow connector with a good one with butt connector.
replaced both airbags and checked fuse which is ok.
what else need be changed?
are there any sensors on the front side like under bumper or around?
I think that control module under center console but clockspring need be changed for sure?
clockspring looks ok....still change it?
I would not mind changing it but we did not change clockspring and put the air bag back in ...so now its diffcult to remove airbag again to put the clockspring ...it always goes bad when airbags deploy? is there any way we can check if its ok or not?
after replacing airbags airbag light still is on I believe becuase we have not changed center control module?
do we need to reprogram using tech 2 or something?
vikasevan is offline   Reply With Quote
Old 04-16-2015, 08:01 AM   #2
Default Re: When airbags deploy clockspring needs be changed?
Clock spring and SDM if there is one inGen-3
Old 04-16-2015, 12:21 PM   #3
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
A tech II can read airbag codes IIRC and tell you which part needs replaced.
The SDM and clock spring are both designed to be single use items as far as air bags are concerned. It's likely that the spring is bad due to the sudden massive current that is required to deploy airbags
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
wi111y is offline   Reply With Quote
Old 04-16-2015, 12:49 PM   #4
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Can we try this?
We will replace module and see if airbag light goes off than clock spring is ok?
Old 04-16-2015, 01:36 PM   #5
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Replace it all. Do you really want to compromise a safety system because of laziness/wanting to save a few bucks?
I wouldn't.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
colonelhogan44 is offline   Reply With Quote
Old 04-16-2015, 02:20 PM   #6
Steve44
Steve44 is just really niceSteve44 is just really niceSteve44 is just really niceSteve44 is just really nice
Steve44's Avatar
1999 SL1
As I understand it, all interior components of the Airbag system are matched. AirBags, SDM, and the clockspring. If they are not all replaced, the Airbag light will set, and the airbags will not work.
The SL1...The Lucky Car
The SL2..The awesome deal.
The #3 Silver SL2 FIVE SPEED!
World's biggest fan of doing it the easy way.
Old 04-16-2015, 02:28 PM   #7
Clockspring is more or less generic. Go to Nalley and find the part numbers and that will tell you what years swap. Generally the bags and SDM have to match to the model year.
Old 04-21-2015, 11:38 PM   #8
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Even though airbag (2002)and clockspring(2001) are from different year cars ...airbag light is not on ...as long as airbag light is not on ...is it ok?
Old 04-21-2015, 11:44 PM   #9
Yes, the Nalley listing tells you all years that use a specific part. If the bag light is off then they are happy.
Old 04-21-2015, 11:46 PM   #10
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Great...thanks all..particularly oldnuc
Tags
airbag
Airbags Did NOT deploy outlook33 Outlook General 18 04-16-2008 04:30 PM
Anyone Have Side Curtian Airbags Deploy? The Budman Vue General 30 11-07-2005 04:25 PM
Airbags did not deploy :[ playboykittn S-Series General 18 10-19-2005 04:24 PM
How fast do you have to be going for the airbags to deploy? TIMSPEED S-Series General 10 10-14-2005 02:06 PM
air bag non-deploy? SaturnFamily L-Series General 14 06-03-2003 09:03 PM
