Old 04-14-2015, 09:48 AM   #1
SuperGreen
SuperGreen has a spectacular aura aboutSuperGreen has a spectacular aura about
SuperGreen's Avatar
Default What mystery compound do you fill Dog bones with
So I've purchased decent aftermarket Dog bones (DEA)...
...I know I know...OEM or bust... whatever. They need to be replaced and Its proven too difficult and costly to purchase OEM ( I've already replaced the TAM with a genuine GM mount and it set me back 75 bucks and I'm trying to replace all mounts without breaking the bank)
ANYWAY... I've heard of fine results with these mounts as long as you fill the remaining gaps in the rubber with a Polyurethane material. What is said material, and what particular hardness is required/best to use.
Thanks for the input.
SuperGreen is offline   Reply With Quote
Old 04-14-2015, 10:27 AM   #2
billysvue
Default Re: What mystery compound do you fill Dog bones with
Looks like McMasterCArr and 3M have 2-part polyurethanes.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 04-14-2015, 10:35 AM   #3
What's the mystery? http://www.ebay.com/itm/PROTHANE-TOR...-/271833842431
Old 04-14-2015, 11:05 AM   #4
SuperGreen
SuperGreen's Avatar
I paid 30 for both mounts, not going to spend close to 40 on inserts, I'm not road racing, just want the motor/acceleration feeling better than it does now ( most definitely ****ty dog bones).
I think doing a solid job at filling these will suffice, they seem to be decently built.
Old 04-14-2015, 11:37 AM   #5
SuperGreen
SuperGreen's Avatar
http://www.homedepot.com/p/Tremco-10...-202267308-_-N
Old 04-14-2015, 11:49 AM   #6
billysvue
THat's a one part sealant made to be flexible- you want it stiff.
Windows/doors, yes, dogbones, doubtful.
'17 Suby Forester
Old 04-14-2015, 12:14 PM   #7
J N Winkler
J N Winkler is a jewel in the roughJ N Winkler is a jewel in the roughJ N Winkler is a jewel in the rough
SuperGreen--no 1997-2002 OEM dogbones at the junkyards near you?
J N Winkler is offline   Reply With Quote
Old 04-14-2015, 01:56 PM   #8
SuperGreen
SuperGreen's Avatar
honestly dude I have such little time outside work, and ****. My mounts are bad, my motor moves a decent amount when going over the mutliple speed bumps at my apartment complex ( at very slow speed) and when accelerating,shifting,stopping. To set aside the time to go to the junkyard, remove the necessary parts, and then have the time to install them, would be too long of a process, I ordered the DEA ones on amazon for $30 bucks shipped (for 2x) and i'm going to replace them today after work with the couple hours of daylight left after 5pm.
I'm going to drive easy on the car, I don't road race or dump on it, every so often I drive it spirited, but I can't afford repairs so I drive her easy. I don't see these being an issue.
Old 04-14-2015, 02:13 PM   #9
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
They will be fine for short term. I have Anchor dogbones on my car currently. The poly inserts I put in my OEM dogbones resulted in too much vibration for me to be comfortable with even with a new OEM trans and engine mount (these are now in a box on a shelf).
lamping.ap is offline   Reply With Quote
Old 04-14-2015, 03:00 PM   #10
J N Winkler
Originally Posted by SuperGreen View Post
honestly dude I have such little time outside work, and ****. My mounts are bad, my motor moves a decent amount when going over the mutliple speed bumps at my apartment complex (at very slow speed) and when accelerating, shifting, stopping. To set aside the time to go to the junkyard, remove the necessary parts, and then have the time to install them, would be too long of a process, I ordered the DEA ones on amazon for $30 bucks shipped (for 2x) and I'm going to replace them today after work with the couple hours of daylight left after 5pm.
It's your decision, of course, but if you later find reason to revisit it, I think you could easily be in and out of a junkyard with a pair of serviceable OEM dogbones within an hour. My last visit to a junkyard took about two hours and I was pulling battery straps and an IATS connector as well as the dogbone. My skill level working on these cars is such that thermostat jobs other people describe as taking "20 minutes" take me about three hours.
Good luck getting the new dogbones installed. I personally wouldn't bother with trying to fill the webbing.
Old 04-14-2015, 08:23 PM   #11
boatmoter
boatmoter is on a distinguished road
boatmoter's Avatar
1993 SL2
what is used is windshield-urethane.. get it at most parts stores, spray good to clean with carb or brake clean,let dry, fill em up and let cure for 3 days.. did the ones on my Neon..
boatmoter is offline   Reply With Quote
Old 04-14-2015, 11:09 PM   #12
Signmaster
3M Window Weld is one of the common things used. 55-60 durometer.
Marine Adhesive 5200 (also 3M) I think it falls in the 65-70 hardness durometer rating. Probably higher sheer strength than the Window Weld stuff.
Sticky stuff, use with gloves and have clean up stuff on hand. Neither is cheap, but they work. And don't put the 5200 on anything you want to remove it from. You have been warned!
Old 04-14-2015, 11:22 PM   #13
Zephy
Zephy is on a distinguished road
1994 SC2
Not to give you any crappy ideas, but some of the older fashioned guys in the racing community here make their own bushings out of hockey pucks. They're cheap and made of a very hard polyurethane. I haven't tried it myself though, so if you're gonna try it lets just pretend you thought it up on your own
Zephy is offline   Reply With Quote
Old 04-15-2015, 10:35 AM   #14
SuperGreen
SuperGreen's Avatar
That's a darn smart idea.
Old 04-15-2015, 01:53 PM   #15
lamping.ap
I've read about guys on the Infiniti G20 forum doing this as well. Also, have not tried myself.
Old 04-16-2015, 12:14 AM   #16
Signmaster
Seems like a hockey puck wouldn't be far from a solid mount. Then again, anything that hits you in the shin at high speeds often feels solid.
I've seen other forums where people are rebuilding different mounts using the various types of urethanes and such. Really it's probably reasonably cheap compared to buying new mounts, but you have to find the right stuff to use for each application.
Old 04-16-2015, 02:56 PM   #17
SuperGreen
SuperGreen's Avatar
I have my original first generation solid aluminum mount, I wonder if I could remove the original rubber and bolt pass through, cut out a fill with a hockey puck on a band saw, and drill out a hole for the metal sleeve for the bolt, lol would be so ghetto, but those original mounts are beefy as **** compared to these aftermarket mumbo jumbo
Old 04-16-2015, 05:44 PM   #18
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
First gen aluminum mounts were changed for a reason... brittle if I remember right.
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
wi111y is offline   Reply With Quote
Use Anti-seize compound? BASL2 S-Series Tech 9 09-24-2008 04:49 PM
Wax compound? NVMY03GT S-Series General 1 01-02-2007 04:35 PM
Scratch Remover/Buffing Compound jddowns Vue General 10 04-09-2006 02:31 AM
Compound/ polish question- jcono Vue General 24 08-22-2005 06:08 PM
rubbing compound for scratches? pauljaws Ion General 5 12-29-2003 04:30 PM
