Old 11-28-2010, 08:04 PM   #1
Diezeltitan08
Diezeltitan08 is on a distinguished road
Diezeltitan08's Avatar
2002 SL1
Default deebs rebuild questions
ive been searching but i keep finding bits and pieces and i jus want to make sure i have this right. i have a running 95 motor with a cracked head...so i guess its walking lol but im using this as a base. i can get any head i want cuz i have an amazing junkyard and my buddy works at a machine shop so all that's free but i don't know if my parts lists is correct. and i wanted some info on where to drill the oil drain holes
95 block
98 head & i/m
93 valves
95 pistons/rods
95 crank
96 fuel system with return
96 pcm
shaved head-whats the most i can deck it without losing reliability?
p&p intake
all comments are welcome, love the help guys and gals
Im Not the Best, Im Just Better Than You!!!
S2N=Second II None( da crew)
GiGi=98 sl2 5spd
Diezeltitan08 is offline   Reply With Quote
Old 11-28-2010, 09:20 PM   #2
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Default Re: deebs rebuild questions
http://www.teamscr.com/motorsports/tech-articles.html
They talk about a few of the components from the Deebs build, and also decking the head. .02" is the usual.
* Shave the head taking off 0.50mm will bump the ratio from 9.5 to about 10.2
* Install the flat faced intake and exhaust valves from a 1991-1993 DOHC this alone will bump the ratio +0.3
"any block will work, 99+ are stiffer
99 rods and pistons, pre-99 crank
01+ lower block brace to stiffen things up
valves are typically 91-93 flat faced version and use 98 valve springs due
to increased stiffness
head isn't as important, stay away from 91 and 99+ stuff
This basic combination netted us 133 horsepower at the wheels, which
translates to 145+ at the crank and the motor was a screamer"
91-93 header will add a few ponies. Since you're in there, swap the cam on the exhaust side for another intake cam. Bore your TB, or get the Geo Storm one. You can get a pretty good build from JY parts.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
quiksc2 is offline   Reply With Quote
Old 11-28-2010, 09:38 PM   #3
Started kicking myself after I took the head off the '96 block. Had my old '93 engine installed & running in my SC2 by then. Could have done a bit of a comp bump for free then but was told there was a hole in a piston in the '96 engine so I took the guys word on it. Oh well, theres always next time for putting a '93 head on a maybe '96 block (engine in the car when I bought it was the 2nd one that it had so I dunno if it was a '96 or not...) Stupid broke valve... lol
Old 12-04-2010, 09:29 PM   #4
Diezeltitan08
2002 SL1
and for the pistons, should i jus get new ones or would jy pistons cleaned up be ok?
GiGi=98 sl2 5spd
Rebuild questions triple_el S-Series Tech 24 08-15-2008 05:23 AM
Rebuild Questions Cincyperf S-Series Tech 3 09-12-2007 09:53 AM
Deebs Rebuild quiksc2 S-Series Mods 2 10-28-2006 02:33 PM
Deebs rebuild? THX712517 Mods and Performance 32 04-21-2003 08:30 PM
The infamous Bill Deebs.... BlackBirdRacing Miscellaneous Tech 4 03-10-2003 07:45 PM
