Old 09-30-2010, 01:45 AM   #1
Tobygot
Tobygot is on a distinguished road
1999 SW2
Default air intake sensor
Hi, i have a '99 SW2. I noticed on the intake tube that's before the air filter, there is a sensor. Is this a mass airflow sensor?
I also have a hole on the side of my airbox on the side where the upper coolant hose runs past that looks like it probably used to have a cap on it.
Would this hole be altering my air/fuel mixture since a lot of the air going into my car is not going past the sensor?
Thanks
Tobygot is offline   Reply With Quote
Old 09-30-2010, 08:26 AM   #2
DonP
Default Re: air intake sensor
The sensor is probably the air intake temp sensor, similar to the ECTS.
Fuel / air mix is monitored by the O2 sensor once is is warmed up. The hole likely has no significant effect under normal operatign conditions.
The hole is probably for a missing sound supression box that connected to it (sort of a resonant cavity - I forget the part name - intended to smoth out the air flow and related sound). It connected via a roughly 1 1/2 inch diameter hard plastic tube. This box was attached to the top back side of the radiator.
Old 09-30-2010, 10:34 AM   #3
That _is_ the air intake temp sensor (IAT). Our cars do not have a mass airflow sensor.
Your car is evidently missing the intake resonator (I bet it sounds a bit "rice-y", right?). As said, air/fuel mixture happens way downstream, so that's not affected, but what is affected is related to your first question. Since the engine is pulling in some air that's not measured by the IAT, and since that air (the hole being near the exhaust manifold) is usually warmer, the PCM is being "fooled" in part about the temp of the air that the engine is breathing. You can fix that by finding a replacement resonator at a junkyard, or simply plugging the hole; it's said that a cap from a gallon jug (such as anti-freeze) fits it quite nicely.
Old 10-01-2010, 05:09 PM   #4
jbracefan1977
jbracefan1977 is on a distinguished road
My brother swears by kn, are there any others that are better
jbracefan1977 is offline   Reply With Quote
Old 10-02-2010, 08:44 AM   #5
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Krappy Non Filtration
underthehood is offline   Reply With Quote
Air intake sensor orientation? BArru L-Series Tech 1 09-04-2010 02:16 AM
intake sensor? napalmer S-Series General 12 03-07-2005 03:11 PM
intake sensor? napalmer L-Series General 2 02-09-2005 05:46 PM
Air Sensor on intake not working... Vipe S-Series Tech 3 08-11-2002 11:54 PM
air intake sensor cabo5150 Miscellaneous Tech 8 06-06-2002 04:14 PM
