Old 07-21-2009, 12:16 AM   #1
Athey
Athey is on a distinguished road
1995 SC1
Default 10w-40 Oil
So, long story short. I end up putting 2 quarts of 10w-40 in, read the manual, and in fine print it says..
"As shown in this chart, SAE 5W-30 is best for your vehicle. However, you can use SAE 10W-30 if it's going to be 0 degress Fahreinheit or above. These numbers on an oil container show its viscoisity, or thickness. DO NOT use other viscosity oils such as SAE 20W-50 or 10W-40."
Will that oil have any serious effects? Im getting an oil change from a buddy in a week and i bought a case of 10W-40 should I just buy a new case of 5W-30? Thanks.
1995 SC1
113k Miles
SOHC
Athey is offline   Reply With Quote
Old 07-21-2009, 12:32 AM   #2
mr18436572
mr18436572 is on a distinguished road
2000 SL2
Default Re: 10w-40 Oil
From what I've read, 10w-40 is not as stable as other grades.
5w-30 and 10w-30 is suitable for any car, in almost any climate. I've used 20w-50 on motorcycles, and never had an interest in using 10w-40.
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
mr18436572 is offline   Reply With Quote
Old 07-21-2009, 12:35 AM   #3
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
OMG it's the end of the world as we know it, and it's unstable.
SaturnSdn is offline   Reply With Quote
Old 07-21-2009, 12:39 AM   #4
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
my car burns oil semidecently
I ran 10w-40 i got 400 miles, against my will (my father)
I ran 10w-30 i got 800 miles
run 5w-30 or 10w-30, it's what's recomended, return that case and swich it
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Saturninin is offline   Reply With Quote
Old 07-21-2009, 12:39 AM   #5
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: 10w-40 Oil
1995 SC1
113k Miles
SOHC
I would not worry about it too much, as you already had 2 QTS of (X grade) in the engine already..
And yes, Return that 10W40, and Get 5 or 10 W 30.
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Old 07-21-2009, 12:39 AM   #6
Athey
1995 SC1
Thanks for the input!
Last question. How many quarts fills it up?
Old 07-21-2009, 12:41 AM   #7
crystal scan
crystal scan is on a distinguished road
2003 ION-2 Sedan
1995 SC1
113k Miles
SOHC
just run what they say to run unless you wantto twinker around
crystal scan is offline   Reply With Quote
Old 07-21-2009, 12:44 AM   #8
Saturninin
Saturninin's Avatar
I believe it is little over 4 quarts, I've not did my oil yet, but it is due soon, yippeee
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
95 SC2 ~128
Past
96 SW2, 98 SL2
Old 07-21-2009, 12:47 AM   #9
Athey
1995 SC1
Ahah thanks. Next step, getting that damned front end fixed!
Old 07-21-2009, 12:49 AM   #10
mr18436572
2000 SL2
I always put in 4.5 quarts. Leaves it slightly overfilled.
Old 07-21-2009, 09:48 AM   #11
MikeNW
MikeNW's Avatar
1997 SL
For my 97, it's 4 qts.
Also you are supposed to use oil with the "starburst" symbol which is 5w-30 or 10w-30. The -30 weights are "energy-conserving". Something about additives. Modern engines are built to closer tolerances. So the -40 and -50 weights are not needed anymore.
BUT 10-40 is better than NO oil! Temporarily.
(I put 20w-50 car oil into my Honda Shadow for its first oil change. Then I asked the dealer why there is car oil and motorcycle oil. "GET THAT OIL OUT OF THAT BIKE!" he said. "IT WILL RUIN IT!"
Bull. It will outlast me. MC oil just makes more profit for dealers. There is a lot of B.S. out there.)
But use the correct grade for your Sat.
97 SL. Bought 7/07, reluctantly sold Dec 2019
Burgman 400- indestructible beast
Sportster 883- fun bike
Cannondale 29er- daily driver
Old 07-21-2009, 11:42 AM   #12
lewdwig
lewdwig is on a distinguished road
I'm topping off the used car dealer fill with 10W-40 Maxlife as needed until I replace the cam cover gasket on my '96. Then I'm going to run M1 0W-40. If you're using a conventional oil, I'd recommend 5W-30, maybe Pennzoil.
lewdwig is offline   Reply With Quote
Old 07-21-2009, 11:55 AM   #13
Gee, I wonder what that afterthought-of-a-manual might say....
Can 10w-30 really cause the oil pressure light to come on? redirwol1 S-Series Tech 7 05-13-2007 09:37 PM
10w-30? SaturnVLN Ion Tech 11 02-22-2007 02:19 AM
5w-30 or 10w-30? tmaugham S-Series General 16 05-19-2006 10:42 AM
opinion on NAPA 10W-30 motor oil? DeMAN S-Series Tech 13 05-09-2006 09:42 PM
Mixing oil 5w-30, 10w-30 oops Magictom Miscellaneous Tech 18 02-24-2004 04:40 PM
