Old 11-10-2008, 08:55 PM   #1
ob2705
ob2705 is on a distinguished road
ob2705's Avatar
2008 SKY Red Line
2008 VUE 3.6L
Default Speed Limiter Removal S-Series FREE
I had some people ask me the last time we were at Daytona running in the ITA class how we got our car to 142 mph....I thought I posted this here a while ago I guess not. It used to cut out at 127 with the early auto PCM.
It's EZ.
We got axles from an abs equipped car and took the speed pick up gears off the axle, We welded (filled) four in a row and left four open all the way around the gear so the tooth count was half as much.....it reads 60 at 120. You do have to disconnect the TSS switch (plug). it tricks the computer and does not shut the fuel off or anything else.
The tach works and all the other gauges, no ses lights or anything.
O.B.
1997 SC
ITA SCCA
ob2705 is offline   Reply With Quote
Old 11-10-2008, 09:00 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Speed Limiter Removal S-Series FREE
It's EZ.
O.B.
1997 SC
ITA SCCA
And your speedo works how?
SaturnSeries.net owner
Old 11-10-2008, 09:02 PM   #3
ob2705
ob2705's Avatar
2008 SKY Red Line
2008 VUE 3.6L
The speedo works half speed when we race but if you wanted to have it for street use just plug the tss plug back in.
O.B.
TopSpeed Racing
97 SC2 ITA SCCA
2008 Sky Redline
Old 11-10-2008, 09:33 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
None of that makes any sense. The PCM doesnt use the the ABS system to determine speed.
Somethings missing in your explaination.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 11-10-2008, 09:53 PM   #5
ajs_saturn
ajs_saturn will become famous soon enoughajs_saturn will become famous soon enough
ajs_saturn's Avatar
2001 SC1
interesting... so i could make my car go 216mph
psssh, yea right, i'll probably die at 140
2001 SL1 5spd - DOHC swap and MS in the works
Bought 02/27/14
2000 SL 5spd
Bought 04/05/05
Sold 06/14/10
ajs_saturn is offline   Reply With Quote
Old 11-10-2008, 11:53 PM   #6
s-seriesguy
s-seriesguy will become famous soon enough
I doubt many here have a s-series that is capable of going that fast on a track. It would have to be on a 2 mile downhill straight away.
s-seriesguy is offline   Reply With Quote
Old 11-11-2008, 05:29 AM   #7
westwind999
1999 SW1
I'm not sure how the ABS sensors are used either? I would think that the Vehicle Speed Sensor on the transmission would be the one you need to modify. It seems to work the same way.
Old 11-11-2008, 07:49 AM   #8
S3aturnR
S3aturnR's Avatar
1999 SL1
all this means is that there are going to be a LOT of kids doing this mod who have no business driving that fast. sounds like it takes a bit of welding skill, so that may thin the herd a little...
s3aturnr
Old 11-11-2008, 11:31 AM   #9
ob2705
ob2705's Avatar
2008 SKY Red Line
2008 VUE 3.6L
Westwind, u r right.
I got with my crew chief to see exactly what he did.....I am just the driver lol.
Alright sorry I left something out...was at work and it was gettin late.
We took an ABS speed pick up and wired in to the VSS (vehicle speed sensor plug in) when you trick the sensor by filling in the notched gear so that the loop is thinking it is going slower than it is. It works great
if you want pics I can get them.
O.B.
O.B.
TopSpeed Racing
97 SC2 ITA SCCA
2008 Sky Redline
Old 11-11-2008, 01:31 PM   #10
rc1488
rc1488's Avatar
Ah now that makes sense.
Old 11-12-2008, 12:55 AM   #11
eRic 02sc2
eRic 02sc2's Avatar
O.B.
ah ok. my Saturn(s) doesn't have ABS. yes please post the pics like this
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 11-12-2008, 01:55 AM   #12
ob2705
ob2705's Avatar
2008 SKY Red Line
2008 VUE 3.6L
you dont need abs you just need the gear (rings) off of an abs axle and a abs speed sensor.
I will be working in the shop tomorrow i will get pics.
O.B.
TopSpeed Racing
97 SC2 ITA SCCA
2008 Sky Redline
Old 11-12-2008, 02:50 PM   #13
In English (which includes capitalization, etc.): this mod uses an otherwise-unused ABS reluctor and sensor as a "surrogate" VSS signal generator. Being after the final drive ratio of the differential, and probably having fewer reluctor teeth than the VSS reluctor in the tranny, it sends fewer pulses per given distance than the VSS reluctor/sensor, thereby sending a lower speed reading to the PCM. Actual speed is thus higher than that "reported" to the PCM, and therfore when the PCM reaches the "perceived" 124 MPH limit speed, the car is actually going faster. Ingenious.
Of course, on a car actually equipped with ABS, the ABS would fail. An even cooler fab would be a dash switch that would, in one position, leave the ABS hardware and VSS connected as normal ("road mode"), and in the other position, disable the ABS and feed the VSS connector with the ABS signal as described herein ("race mode").
Of course, this also does not remove the speed limiter. It only raises the maximum speed.
Oh, and don't forget, if/when you sell the car, you'll have to indicate on the title that the odometer is wrong.
Old 11-12-2008, 03:49 PM   #14
wishihadacamaro
wishihadacamaro is on a distinguished road
Yeah, but good luck getting a Saturn to go 248mph!
wishihadacamaro is offline   Reply With Quote
Old 11-12-2008, 04:48 PM   #15
I think if you dropped one out of an airplane nose first, terminal velocity would be somewhere around there.
Old 11-12-2008, 11:30 PM   #16
ob2705
ob2705's Avatar
2008 SKY Red Line
2008 VUE 3.6L
madpogue you are that smart and from Wisconsin!!!
I am origanlly from Stevens Point that's why it was harder for me to explain it like you did.....It gets a lot colder up there and our chicks were fatter,,,
Thanks for explaining it in english
O.B.
TopSpeed Racing
97 SC2 ITA SCCA
2008 Sky Redline
Old 11-13-2008, 12:35 AM   #17
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
Very interesting approach! Never heard of anyone doing that before.
I still think it's easier to install a megasquirt, but you can print a custom speedo that'll go to over 200 mph this way. Haha, nice.
2000 SL2 5-speed turbo
MSnS-E fuel & spark controlled @ 17-20 psi (methanol injected)
Fully forged, P&P head and manifolds, FSR turbo cams, balanced to 9k RPM
http://www.cardomain.com/ride/3070918
plastic torpedo is offline   Reply With Quote
Speed limiter removal??? Jarryn S-Series Mods 35 01-27-2016 05:42 PM
speed limiter removal DMVue Vue Mods 41 12-22-2007 01:17 PM
speed limiter t0pk0w S-Series Mods 37 01-24-2003 01:09 AM
Speed limiter WHITE98SL2 General Saturn Discussion 18 05-31-2002 08:58 PM
What is the speed limiter for a 99 SL Son93SL2 S-Series General 19 05-17-2001 03:45 PM
