Old 06-21-2008, 05:03 PM   #1
rockermikey
rockermikey is on a distinguished road
1999 SL1
Dizzy Oil Light Stays On
Hi there...the oil light on 1999 SL 1 with 178 000 km's on it stays on for a couple minutes then goes off. I noticed that once oil reaches the valves it goes off. I can tell by the noiseyness of the valves. One day it would'nt go off at all and had it towed to my shop. The mechanic said it could be one of 2 things..the first being the filter in the oil pan being plugged...can do one of 2 things there...do a hot engine flush ....$120 or remove the oil pan and clean or replace the filter...$400-600!. The other option was replacing the oil pump....$700-900!!!....I opted for the hot flush with some kind of chemical added in the new oil for $120. Now today the light will not go off. Does anyone think it could be the filter in the pan?..or do I have to replace the oil pump....or is something totally different....he also said while he's got it apart may as well replace the timing chain. I thought it wasn't necessary to do being a chain. Also...is it dangerous to drive with the light on? Any help will be greatly appreciated. He also tested the oil pressure and it the readings were 10 psi at idle (which is low according to him) and 40 psi at fast idle which was in the range. Thanks in advance...
Cheers
Mike
rockermikey is offline   Reply With Quote
Old 06-21-2008, 05:23 PM   #2
stang50
stang50 is on a distinguished road
stang50's Avatar
1997 SL1
Default Re: Oil Light Stays On
If your pressure is at 10 psi idle then you have a big problem. It could be your oil pump, your main bearings are gone. You are about to have to have a blown engine if you don't hurry up and get the pressure up...
stang50 is offline   Reply With Quote
Old 06-21-2008, 05:29 PM   #3
Uzzy
Uzzy's Avatar
2002 SC1
Ok, so he thinks the filter is plugged then he recommends the $120 flush? The flush forced more crud into the oil pickup filter, not less!! The pan needs to come off to see what's really going on. He soaked you for an extra $120 with the flush and he knows it. You got hosed. And the flush was bunk to begin with. Use good oil and you don't need a flush.
Aut viam inveniam aut faciam
Old 06-21-2008, 06:21 PM   #4
rockermikey
1999 SL1
I guess you are right....this was about 3 months ago and it didn't really start acting up till the other day....My bad.....
Old 06-21-2008, 09:20 PM   #5
dsbike
dsbike is on a distinguished road
I would replace the oil pump & clean the screen/filter in the pan. While the mechanic is in there I would have him check the tollarances of the timing chain, if it is bad replace it.
dsbike is offline   Reply With Quote
ABS Light / Battery Light Stays ON + starter issues 97 SL1 IanDorety S-Series General 3 08-25-2009 11:08 PM
Oil pressure light stays on too long orneryhermit S-Series Tech 13 11-26-2007 10:53 AM
ses light stays on dewrat S-Series Tech 10 08-02-2006 09:08 PM
Oil light stays on mrbluesky S-Series General 12 03-31-2006 03:33 PM
change oil soon light stays on along time mclarenf1gtrv12 S-Series Tech 2 11-23-2003 07:04 PM
