Old 04-30-2021, 02:07 PM   #1
burnt orange
burnt orange is a jewel in the roughburnt orange is a jewel in the roughburnt orange is a jewel in the rough
Default 03 Vue..3.0 .. 150k miles..cutting out on startup.
For some reason..Never done that before. Mechanic says probably a leaky
vacuum hose. Does that sound familiar to anyone? Is there an area I
could put some soapy water on to look for leaks? thx in advance..bo
burnt orange is offline   Reply With Quote
Old 05-01-2021, 12:42 PM   #2
Default Re: 03 Vue..3.0 .. 150k miles..cutting out on startup.
Anyone, including mechanics, can make armchair quarterback guesses at your expense. Some background history may help to draw a picture of your Vue's maintenance. Is the check engine indicator on after the random engine die off?
Old 05-01-2021, 02:01 PM   #3
burnt orange
He is a volkswagon mech working weekends for people. He replcd the valve
cover gaskets a little while back. Has done some brake work on the Vue. He
did a diagnostics each time he has it and found a thermostat warning one time
and a p2008 i've decided not to address right now. It doesn't really die off..It
just chugs along about 6 - 8 rpm. Car has been maintained well and usually
pretty quick for 150k miles...the mechanic likes the engine..said gm finally
did something right...He has scheduled it for next weekend..I just thought
I would look to see if I could spot the leakage...I guess soapy water isn't that
great an idea since it might get sucked into the engine if there was a leak.
Old 05-01-2021, 02:18 PM   #4
Was the timing belt replaced at 100k miles? Spark plugs at 100k miles?
P2008 Intake Manifold Runner Circuit Open Bank 1 - Read more at: https://www.obd-codes.com/p2008
If the IMRC valve is stuck in the open position, the shorter intake passages, normally used during wide open throttle but closed in everyday driving to use the longer passages, may be the reason for this issue. It's not wise to ignore error codes unless you have an open wallet for repair shops to pad a bill. This description might be the worse case scenario with best case being a dead or disconnected solenoid. The imrc valve uses vacuum to operate the intake manifold blade to switch from long passages to short ones for performance during wide open acceleration. If the blade is stuck in the performance mode, this may be affecting normal idling, startup and regular driving. The solenoid is electrically commanded by the ecm when the throttle position sensor is at wide open throttle. The solenoid valve controls the vacuum diaphragm that pulls the intake blade inside the intake manifold open. A spring returns the blade to closed position for normal driving. Vacuum, power and solenoid operation are checked to determine where fault lies. Power is 12v applied directly to the solenoid to listen for valve operation, a single click as the valve moves from deactivated position/closed to activated/open position, allowing vacuum to operate the vacuum valve diaphragm. The imrc should be on the right side of the engine, opposite the throttle body.
Plain water is good enough if there's a vacuum leak as water won't harm an engine idling. Any water sucked in with an idling engine simply slows rpm immediately or stops the engine. An alternate fluid can be almost any solvent that would ignite when ingested into a vacuum leak, raising rpm.
If this were my vehicle, I would jump on the error code and begin troubleshooting instead of ignoring it.
Old 05-08-2021, 01:26 PM   #5
burnt orange
Got lucky...Vacuum hose on starboard side had come off the post..
Old 05-08-2021, 02:11 PM   #6
Buy your mechanic............... Apparently you have a great one on your side.
03 Vue..3.0 .. 150k miles..Noise, smoke around.. burnt orange Vue General 3 03-10-2021 10:07 AM
150k!!!!! iamdigitalman S-Series General 7 10-05-2013 07:35 AM
Value of a 98 SL1 Manual with 150k bri2203 S-Series General 8 09-24-2009 09:18 PM
Hit 150k on my SL today! lukecp S-Series General 0 01-15-2006 09:57 PM
'02 V6 With Blue Smoke on Startup - 32k Miles dmccreary860 L-Series General 3 06-16-2005 03:58 PM
