Old 04-09-2019, 08:20 PM   #1
Buckmeister
Buckmeister is on a distinguished road
Default Door arm popping
What is this thing? Picture attatched.
Pops on all 4 doors they all move whenever the pop happens, drives me nuts, grease did nothing.
EDIT: Found out its called a door check. Would there be any problems besides the door not staying open if they were removed?
Has anyone found an alternative to this issue than replacement? New ones i can find are 44 a piece or so.
Buckmeister is offline   Reply With Quote
Old 04-10-2019, 06:43 AM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Door arm popping
...You do need those ,otherwise the door will swing wide open in the wind with no stop. Try visiting your local junk yard for a temp fix.DC
Old 04-10-2019, 08:13 AM   #3
burnt orange
burnt orange is a jewel in the roughburnt orange is a jewel in the roughburnt orange is a jewel in the rough
Wipe the grease off..pull one of the door panels off, not that hard.
Look inside and see whats causing the noise..Do you drive a lot of dirt roads? Sometimes dust can accumulate inside the door and cause problems...
burnt orange is offline   Reply With Quote
Old 04-10-2019, 04:24 PM   #4
Buckmeister
When you open the door, that area where the grease is, it looks like the arm moved where that grease is and you hear a loud pop.
Is the only long term thing to do is buy the expensive door arms?
Old 04-11-2019, 02:54 PM   #5
Grape_Ape
Grape_Ape is on a distinguished road
New are a little over $30 most places, not terribly expensive. You could try a junkyard, but they do wear out, so who knows how long a new one would last. I'd pull the door panel off first and see if they can be clean up and se exactly what's going on. Grease is not usually a good fix for them, as it attracts dirt. I'd use a dry graphite lube.
Grape_Ape is offline   Reply With Quote
Old 04-15-2019, 12:26 PM   #6
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
I packed driver passenger with grease and no more pop. Looked to have a compression spring inside. No alternative, dealer part only.
JefferyC is offline   Reply With Quote
Old 04-15-2019, 04:37 PM   #7
Vue6
Vue6's Avatar
2006 VUE Red Line
..Did you check them to see if they have a crack in them,at the small end? That is why they usually start popping ,mine did on the driver's door, that grease will help for a bit, but eventually it will get worse, DC.
99 MP3 popping 3'rd Jack Black S-Series General 3 05-24-2015 12:53 PM
popping when fan is on? athensm50 S-Series Tech 1 03-14-2014 04:30 PM
Astra door check popping Spaztrick Astra General 7 03-07-2013 08:19 AM
L200 Front Door Popping Noise paskitti L-Series Tech 8 02-27-2007 08:34 AM
Popcorn popping sounds from drivers side door/window flavoredair Vue Tech 1 03-15-2006 10:25 AM
