Old 09-26-2013, 08:13 AM   #3061
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Default Re: What did you do to your S-Series today...
Permanently/temporarily mounted my manual fan switch.
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Syracuse":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
sallydriver is offline   Reply With Quote
Old 09-26-2013, 08:45 AM   #3062
trottida
trottida's Avatar
Local independent muffler shop replaced the front flex pipe, connection behind the catalytic converter and the muffler.
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 09-27-2013, 06:29 PM   #3063
Razzle Dazzle
Razzle Dazzle is on a distinguished road
Razzle Dazzle's Avatar
Put on a K&N Air Filter.
'12 Chevrolet Cruze, 1.4T M/T 101k
Miss my White 95 SC2, said goodbye at 213k, 7 years of ownership.
Razzle Dazzle is offline   Reply With Quote
Old 09-27-2013, 11:54 PM   #3064
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
Started exchanging the power steering fluid on both with the turkey baster method to get clean fluid back into the power steering system, also started 2 applications of Auto-RX on their engines.
Old 09-28-2013, 01:20 PM   #3065
Nels
Nels is on a distinguished road
Nels's Avatar
1996 SL
A little long-overdue edging this morning, and the truck is not home, soooo . . . .
Saturn to the rescue!
Nels
Manitowoc WI
1996 SL, 5 Speed manual ╠╬╝
Nels is offline   Reply With Quote
Old 09-29-2013, 12:19 AM   #3066
climbski
climbski has a spectacular aura aboutclimbski has a spectacular aura about
2000 SW2
1999 SW2
Fixed the rear window wiper on my SW2. A little soldering work at the steering wheel switch. Common problem easily fixed. Thanks again to this forum for giving me the heads up before I got to messing with the motor!
climbski is offline   Reply With Quote
Old 09-29-2013, 06:31 PM   #3067
lewdwig
lewdwig is on a distinguished road
Son hit a deer with the 2001, shop replaced axle and control arm bushing on passenger side. I'm in the process of replacing the passenger side headlight, fender and the bumper cover. And a new tire.
lewdwig is offline   Reply With Quote
Old 09-29-2013, 09:18 PM   #3068
guy_450
guy_450 will become famous soon enough
guy_450's Avatar
2001 SW2
2000 SW2
New stuff:
33-2055 K&N Replacement Air Filter
671-4042 Denso Ignition Wire Set
SP-NP21 Pilot Nitrode Nickel Spark Plug
Remove, clean, add some dielectric (spark plug) grease and put back in place ignition coils
2001 SW2 4AT silver (garaged, 2000 SW2 5MT sold)
2013 VOLT, now it is son's DD, it has replaced my former 2002 SL2
2019 VOLT electric instant torque & regen braking + range extender
guy_450 is offline   Reply With Quote
Old 09-30-2013, 12:28 AM   #3069
climbski
2000 SW2
1999 SW2
New water pump. Second Saturn S series that needed one at about 125k. It was easier on the 2000 though. Seems the clearance was improved for removing the wheel. Flushed the manual transmission a second time while I was at it. previous owner had it serviced with engine oil instead of DM3.
Old 09-30-2013, 08:58 AM   #3070
GeekOnTheHill
GeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the rough
GeekOnTheHill's Avatar
Cleaned the throttle body over the weekend to clear up a sticky accelerator pedal problem. It did that, plus delivered a phenomenal improvement in low-RPM performance.
I actually was shocked. I tore gravel up from the driveway the first time I drove the car after that. I never experienced such dramatic improvement just from removing some carbon from a throttle body. I guess it really throws off the physics.
-Richard
GeekOnTheHill is offline   Reply With Quote
Old 09-30-2013, 09:12 AM   #3071
Yes, it does.
Old 09-30-2013, 09:28 PM   #3072
climbski
2000 SW2
1999 SW2
Well based on the above posts I went ahead and cleaned up the throttle body as well as I could without removing it. Wow what a mess, oily gummy buildup. Looking down the hole into the intake is not advised, little pool of oil down there.. lotsa carbon. Depresssing. I don't even want to think about the valves.. Gonna have to remove the TB and maybe the whole intake Manifold and clean her up. Perhaps I'll pour a bucket of Marvel Mystery Oil down there.
Anycase just the minor cleaning I could reach seems to have helped. Does have slightly more pull at low RPMs.
Also bypassed the IAT with 122ohms of resistance. Seems to run fine. Leaning it out a bit up here at 5k feet should be a good thing. But haven't done a cold start yet. I'll see in the AM. Hope I get a nice improvement in MPG.
Old 09-30-2013, 09:49 PM   #3073
YslashN
YslashN is on a distinguished road
1993 SC2
Removed master cylinder for a thorough flushing of the brake fluid, and turned the front rotors since I had the struts off (my work has a brake lathe I get to use whenever).
YslashN is offline   Reply With Quote
Old 10-01-2013, 12:28 AM   #3074
sallydriver
1993 SW2
Went to the junkyard. Bought:
  • an MP3 transmission
  • a door hinge
  • and a shifter control tower
All for $160 bucks. Then went and did safety, emissions, and re-registration for $125.
Ouch.
Old 10-02-2013, 03:17 PM   #3075
1996SW2
1996SW2 is on a distinguished road
1996SW2's Avatar
1996 SW2
2000 SW2
Got the AC fixed up the other day with a seal kit.
Replaced the BW tensioner assembly I put in nine months ago. Bearings were making racket under load from AC. Purrs lije a kitten now.
1996SW2 is offline   Reply With Quote
Old 10-02-2013, 05:17 PM   #3076
kdhunter
kdhunter is on a distinguished road
1993 SL2
Attempting to determine flaky steering after replacing tie-rod ends.
kdhunter is offline   Reply With Quote
Old 10-05-2013, 05:20 PM   #3077
macbox
macbox will become famous soon enough
macbox's Avatar
Took the 95 SC2 out today and rolled over 166,666 miles on the odo.
#4, "Betty" 1995 SC2m, 167K, rebuilt engine, Garage Queen. Still squeaks and rattles but goes like hell.
macbox is offline   Reply With Quote
Old 10-05-2013, 05:59 PM   #3078
climbski
2000 SW2
1999 SW2
Went to the junkyard and got a spring-loaded airdam for my car and installed it.
Old 10-05-2013, 06:55 PM   #3079
Madness10
Madness10 will become famous soon enough
Madness10's Avatar
Got my car smoged today and passed with flying colors. A little higher on the Nox this time, but well in the limits. All I did this time is replaced plugs and cleaned and re oil the K&N air filter.
Madness10 is offline   Reply With Quote
Old 10-06-2013, 01:02 AM   #3080
kdhunter
1993 SL2
Welded a break in the engine cradle/subframe.
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
