Old 01-21-2012, 12:50 PM   #41
madpogue
1996 SW2
Default Re: KREEN internal engine cleaner for oil burning, sludge, etc...
Originally Posted by spacemanspif View Post
1. Can design SUCKS. I used a funnel and still spilled a lot on the valve cover.
MMO used to come in that kind of can (as did a lot of floor care products, thinners, etc). For something this strong, it needs a spout that threads onto the cap threads. Articulated metal spout from an old '60s gas can might fit.
Old 01-21-2012, 06:04 PM   #42
Nawww, it is a coordination test... Everything used to come in cans like that.
Old 02-03-2012, 08:46 PM   #43
lewdwig
lewdwig is on a distinguished road
Originally Posted by blue92 View Post
So, who else wants to be a guinea pig?
I keep saying to myself, "if its sounds too good to be true...."
I plan on trying this in my 1996 this spring in the oil and as a piston so
ak (I get about 400 miles per quart of oil).
I used Auto Rx (an old BITOG favorite) in the 2001 a couple summers ago; it cleaned up the dipstick and the oil doesn't get as dirty as it used to, oil consumption is about a quart in 1,000 miles.
lewdwig is offline   Reply With Quote
Old 06-11-2012, 10:34 PM   #44
lewdwig
I ran some Kreen in my oil (about a cup) for 1K before changing my oil and did an overnight piston soak. Oil consumption is pretty much the same but my dipstick is clean.
Old 06-11-2012, 11:32 PM   #45
racinginblood
racinginblood will become famous soon enough
racinginblood's Avatar
1998 SL1
clean dipstick is good but theres nothing like finding lipstick on your dipstick
racinginblood is offline   Reply With Quote
Old 12-22-2015, 05:23 PM   #46
Virago6
Virago6 is on a distinguished road
2002 SL2, 129K original miles. DD uses it for her daily.
Finally am going to try the Kreen soak after having the can of it on the shelf for a year. Must have gotten redesigned can, as this was easy to pour. I used 500 mL syringe to remove from can top, placing 60 mL / 2 oz into cylinder once I removed plugs.
Oil rate 1 qt per 1500 has gotten to 1 qt per 500 miles. With frequent check/top off of oil, I use dino 5w30. I have had a couple of cases of it that I bought at auction cheap, all meets spec, 5w30 Motorcraft.
Plan is to allow to soak x 36 hurs, vacuum out of engine, place 6 oz into fuel with non enthnol fuel filled, run for 50 miles, drain oil and replce filter.
Will let you know how it goes.
Virago6 is offline   Reply With Quote
Engine Sludge? wfransee Vue Tech 1 03-22-2008 09:57 PM
GM Top Engine Cleaner Vs. Piston and Ring Cleaner Petey S-Series Tech 5 09-09-2005 12:56 PM
Engine sludge JerryHughes S-Series General 4 07-21-2005 01:18 AM
Internal Engine Cleaning RalliArt16 S-Series Tech 14 01-31-2005 03:39 AM
Engine cleaning (internal) 100KSW2 S-Series Tech 7 02-06-2001 07:31 AM
