Old 11-19-2010, 02:53 PM   #1
gareth27
gareth27 is on a distinguished road
1995 SL2
Default Need some advice about my 1995 sl2
Very recently I had a dealership (which was formerly a saturn dealership) change my valve cover gasket. I had oil in my spark plug wells, so I was aware that it needed to be changed. Well 3 days later I noticed pools of oil where I parked, so I checked under the hood and what do I find? It appears that the valve cover gasket is now leaking. I contacted the dealership and told them of the problem and they said to bring it back in. Obviously i'm a little annoyed about this as 1)they should've done the work right the first time, and 2) the dealership is about 20 miles from where I live....so there's a travel annoyance as well. I also noticed that i've been getting really bad gas mileage and the vehicle would seem to heat up very quickly if I was in slow moving/city traffic. The dealership also changed something called the temp sensor and connector. I'm wondering if this is the ECTS that they changed, and also wondering if this could contribute to my poor gas mileage. Any advice would be helpful.
gareth27 is offline   Reply With Quote
Old 11-19-2010, 03:02 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: Need some advice about my 1995 sl2
Usually fixing the ECTS and connector (while SOLDERING+HEAT SHRINK WRAPPING the splices) helps take care of bad gas mileage issues. Did he use the brass one? Also, was it the one wire sensor or the two wire sensor? This matters since the one-wire sensor controls the gauge and hardly goes out. The two-wire sensor is the ECTS.
Besides, the ECTS+connector is ~$15, so why have a shop do it?
Also, you might want to look into a coolant flush and a new thermostat.. It'll help with the gas mileage and help get any crap out of your cooling system.
Old 11-19-2010, 04:21 PM   #3
gareth27
1995 SL2
they also did a coolant flush, so hopefully that helps. I only had the shop do it since I was there doing the valve cover gasket anyways. I'm not sure which part was used, or even if the part they replaced was the ECTS. The part numbers are 1) 12117087- for the connector, and 2) 21025106 for the actual sensor
Old 11-20-2010, 07:05 AM   #4
WingsOfSaturn
WingsOfSaturn will become famous soon enoughWingsOfSaturn will become famous soon enough
WingsOfSaturn's Avatar
1995 SL2
21025106 is the part number for the ECTS. Hopefully they connected it correctly. With enough effort you can switch the two sensor connectors. Your SES light is not on, is it?
"When you stop to fill up on oil, don't forget to check the gas"
98 SL2 MT 213K+ Daily Driver 38+ mpg
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
WingsOfSaturn is offline   Reply With Quote
Old 11-20-2010, 01:43 PM   #5
gareth27
1995 SL2
Thankfully my SES light is not on.
Old 11-20-2010, 01:44 PM   #6
gareth27
1995 SL2
Is the part number that I mentioned above the brass tipped ECTS?
1995 sc-2 mkls0 S-Series Tech 1 09-01-2010 11:28 PM
advice on a 1995 saturn sl juboqu S-Series General 12 11-15-2008 03:00 AM
1995 SOHC swap to 1995 DOHC Dreamimage S-Series Mods 19 01-26-2008 01:54 PM
1995 SC2 failed emissions - need advice adams80 S-Series Tech 21 06-02-2005 03:43 PM
Advice, please on sway bar & strut brace advice for 1998 SL2 DOHC. TimothyD S-Series Mods 12 06-21-2002 12:34 PM
