Old 06-24-2010, 12:35 PM   #1
truck1985
truck1985 is a jewel in the roughtruck1985 is a jewel in the roughtruck1985 is a jewel in the rough
2004 ION-3 Sedan
Dizzy Can't seem to fix this car?!?
I have a 2004 Saturn Ion 3 with the 2.2L Ecotec and 5 Speed Manual Transmission. About 2-3 months ago, I very abruptly started getting a lot of noise from the engine. About two days later, a gouge appeared in the valve cover. Upon further investigation, I found that two of my timing chain guide had catastrophically failed. I changed out the entire timing kit, valve cover, and dropped the oil pan and cleaned it. Since then, the problems seem to keep coming. My IAC (idle air controller) went bad (I have replaced it). I started getting a p0172 DTC (system too rich) and P0107 (MAP/Barometric Pressure Sensor). I have removed the Catalytic Converter to make sure it wasn't clogged (didn't fix the problem so I reinstalled it). I have changed the oil several times. I have replaced the spark plugs twice. I have replaced both my upstream and downstream O2 sensors. I have replaced the MAP Sensor twice. I am still getting the engine error codes, even after all of this. I ran a fuel pressure test. I got good results from that, except when the engine is idling, the pressure is all over the place when I am idling. The engine does idle a little rough. My research elsewhere has told me to replace the Fuel Pressure Regulator (my local GM dealership tells me there isn't one on the '04 Ion). I am at my wits end, and am tired of throwing parts at the vehicle. Does anyone have any suggestions? I don't want to take it to a shop if I don't have to--please help?!?
truck1985 is offline   Reply With Quote
Old 06-25-2010, 05:50 AM   #2
Maritime Storm
Maritime Storm has a spectacular aura aboutMaritime Storm has a spectacular aura about
Maritime Storm's Avatar
2003 ION-2 Sedan
Default Re: Can't seem to fix this car?!?
Are you sitting down? Hook a vacuum guage up to the engine on the intake ports(they are 2) while it's idling, if the reading is low(and I suspect it is), chances are you are pulling the timing cover again to see which cam is out of timing.
Save the Earth, Ban Slushboxes!!!!!
Maritime Storm is offline   Reply With Quote
Old 06-25-2010, 10:35 AM   #3
2006 ion2
2007 ION-2 Sedan
or if you have access to a proper scanner, or have any way of reading MAP, you can use that. I have my MAP and many other parameters available on my scangauge 2
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 06-25-2010, 09:42 PM   #4
ssicarman
ssicarman's Avatar
Welcome to the Board.
The fuel pressure regulator is as far as I know is part of the fuel filter.
As Maritime Storm said recheck the crank to cam timing. If none of this was happening before replacing the chain then it would certasinly point to a problem there.
Old 06-26-2010, 02:27 PM   #5
Maritime Storm
2003 ION-2 Sedan
Yep, just like the last generation S-Series, the regualtor is part of the fuel filter.
Old 06-30-2010, 11:19 PM   #6
truck1985
2004 ION-3 Sedan
The Fuel Filter has been replaced, so I guess that means the problem isn't there. I do have a quality code scanner. It gives a MAP sensor reading of about 16-17 inches of mercury. I know that that reading should be around 12 inches of mercury, though I don't know if that tells you anything. As far as the vacuum gauge test, I just got a vacuum gauge, and will be using it tomorrow, time permitting. Hopefully I don't have to tear the engine down again, that would really tick me off. Thank you for your advice/input, I appreciate it.
Old 07-01-2010, 01:46 AM   #7
2006 ion2
2007 ION-2 Sedan
sounds like you have a vacuum leak if your vacuum is higher than normal (map has too many variables to be truly universal). check your brake booster hose, TB to intake manifold gasket, and intake manifold to head gaskets. if you are still getting high MAP and they look good, replace them.
2007 Saturn Ion 2
Old 07-01-2010, 11:41 AM   #8
ssicarman
ssicarman's Avatar
If you are actually getting a correct reading of 16-17 inches of vacuum then that is a good number. Engine vacuum will vary to a degree on the altitude of where you are, the higher the elevation the lower the vacuum that can be gotten. Your reading is decent. 12 inches would be low at most normal elevations.
Reread your fisrt post.
You say that the fuel pressure readings are all over the place. They certainly should not be. If you got an aftermarket fuel filter it may be worth while getting an OEM one to see if the pressure readings steady out.
You said that you got good pressure results other than at idle. What is the pressure that you are getting that you say is good?
Old 07-02-2010, 09:19 AM   #9
truck1985
2004 ION-3 Sedan
2006 ion2, I am not entirely sure what these items you are talking about are. ssicarman, the fuel filter I installed is OEM (from the dealership). My idle fuel pressure is between 40-70 psi, but when I did the pressure test with the key on, engine off, the pressure was steady at about 55 psi, which is mid-range for that test. As for my MAP reading; I am at sea level...I don't know if that tells you anything, but according to alldata, it should be around 12 inches, being at sea level, when idling. I am not sure how to check that I am getting a correct reading from my MAP. I am getting the reading from my Actron Code Scanner, so I can only hope that it is correct. I still have not been able to run my test with the vacuum gauge. I am hoping to do that today, though I am not entirely sure how, hopefully I can figure it out once I actually open the package for the tester.
p0107, p0172
