Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay General
Old 07-23-2021, 07:29 PM   #1
saturnisthebest
saturnisthebest is on a distinguished road
Question 2005 Saturn Relay Voltage Drop
I have a 2005 Saturn Relay (3) reporting a B1516.
The battery, alternator, battery voltage sensor all have been replaced, and the terminals on the battery cable have been newly terminated with new terminals.
Service Engine Soon light still goes on, and when code is cleared, the voltage drops from 14.2 to 14.7 regular operating voltage, to around around 12.8 - 13.0 volts.
Clearing the code brings its back to regular voltage, until it fails the test exactly 2 minutes. New battery was tested and found good, as well as the alternator. I am at a loss and hoping its not the BCM. Any hints would be great.
saturnisthebest is offline   Reply With Quote
Old 06-29-2022, 11:23 AM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: 2005 Saturn Relay Voltage Drop
Does this vehicle idle with high electrical load for an extended length of time before the light comes on? Or is it random with no pattern?
2002 L200/5 Loaded, over 1/4 million miles!
Tags
alternator, battery, relay, voltage
Saturn vue 2008 left turn light not working ( voltage Drop ) Lyiss113 2008 Vue 0 02-26-2018 10:32 AM
Voltage drop problem xdarkxfirex Astra Tech 1 01-09-2017 08:03 PM
Odd Voltage drop issue 700+SL2 S-Series Tech 27 11-04-2016 12:37 PM
voltage drop when increasing RPMs to 3K visnew20 S-Series Tech 0 07-18-2012 07:22 PM
Rough Idle In D, Voltage/RPM Drop Decaf S-Series Tech 6 02-23-2012 12:49 AM
