#1 |
![]() Join Date: Mar 2014
When I first start it up no matter what time of day or temp car is running bad and stalls then about 10 min at a consistent speed it goes away the codes I'm getting 0404 0405 1404 0341 could one set others off? I replaced the egr and still doing it I'm stumped anyone help me thanks.
#2 |
Any history to this car?
#3 |
Yes the engine has been rebuilt new trimming chain new temp sensor has about 20000 miles on rebuild other than this problem car runs like a dream burns no oil
#4 |
P0404, P0405 and P1404 are egr valve issues. The egr valve only operates during acceleration and cruise, closed while idling or wide open throttle. To check for blocked passages of either the exhaust or intake port under the egr valve; remove it and start the engine - the intake port, if not blocked with carbon exhaust, should have the engine rev up to it's redline limiter and stay there. A blocked intake port from exhaust build up won't allow the engine to rev to its programmed redline. The exhaust port should blow out any loose carbon as the engine runs. If the engine redlines, do this for only a few seconds then shut it off. Testing the intake and exhaust ports covers only the engine. P1404 may be for egr valve failure so testing/eliminating the ports first may reveal a blocked port before troubleshooting a faulty egr valve.
P0341 is about the pseudo cam position error code - an ignition system problem related to the ignition control module and two coils. Remove and clean them of corrosion, paint corroded parts and use some dielectric grease on plug boots to prevent future corrosion and lube them from heat bonding to the plugs. Swapping coils may eliminate the error code too. Hopefully some minor maintenance will eliminate these error codes and allow a new second life to this car. |
#5 | ||
P0341 is usually plug wires 1 & 4 not properly run from the coil packs to the valve cover. Wires 2 & 3 can't run between them at any point, the coil towers need to be clean and the spark plug caps need to be clean.
The other 3 indicate an electrical problem with the EGR wiring. Skip P0404 for now, P0405 and P1404 issues can cause it. Quote:
The proper way to fix a S-Series automatic is to replace it with a manual |
Bookmarks |
no codes! please help..... | eriic1977 | S-Series Tech | 11 | 02-21-2011 02:57 PM |
Codes | Saturninin | S-Series General | 0 | 01-13-2011 07:56 PM |
Got my codes read.. the autozone rep was surprised to see soo many codes... oh no | bskicrash1 | S-Series General | 2 | 11-12-2006 02:10 PM |
SES Codes (beyond the paperclip codes) | rkhassen | S-Series Tech | 11 | 10-18-2006 08:53 AM |
95 SC2 and Codes!!!!! | Ray77085 | S-Series General | 16 | 10-14-2005 07:16 PM |
