Old 05-17-2022, 10:34 PM   #1
radtek
radtek is a jewel in the roughradtek is a jewel in the roughradtek is a jewel in the rough
radtek's Avatar
Default 04 Ion Bad Steering vibration at 60+ mph
I have been working on my Granddaughter's 04 Ion 3, 186K. So far new timing assembly and rebuilt cylinder head. Engine runs nice and smooth now. But discovered new problem today. At 60+ mph a fairly bad vibration starts and gets worse as it hits 65. I had the tires balanced at Les Swab as she got her tires there last year. They balanced them and only notice the need for brakes on the front and no obvious suspension issues. It tracks straight as a pin up to 60. Could this be the lower control arms, sway bar bushings or maybe even the motor mounts. I had the front mount off when changing head it looked fine but dont know if I may have buggered up something raising and lowering the motor while working on it. Anyone else have this vibration issue and figured it out?
radtek is offline   Reply With Quote
Old 05-20-2022, 04:21 PM   #2
radtek
radtek's Avatar
Default Re: 04 Ion Bad Steering vibration at 60+ mph
UpDate: It seems Les Swab did not do a proper job on their balancing act! They told me tires are balanced and only thing they saw suspension and front end wise was it needed brakes. Yesterday I installed new brake pads and happen to notice there was no weights at all on left front wheel. This seem not right! What are the odds of having a perfectly balanced tire and wheel ...so anyway took the wheel back up to them had them re-balance and low and behold it now took 1.25 oz of lead to balance that wheel. It also eliminated the shake and shimmy at 60 mph.
Old 05-21-2022, 12:21 PM   #3
goaliemo
goaliemo will become famous soon enoughgoaliemo will become famous soon enough
2003 ION-1 Sedan
2006 ION Red Line
It may not of needed any weight when the tire was new. I have ran into that myself before. On my personal vehicles and customer vehicles.
But once worn a little bit, its good to have them re balanced. Also a good idea to keep up with rotating for even wear across front and rear.
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
goaliemo is offline   Reply With Quote
Old 05-22-2022, 05:36 PM   #4
radtek
radtek's Avatar
The issues was these tires had about 9 mos of wear and they were balanced the day before. I went for drive after the tires were back on the car and it shook worse then before. I came back the next day with the tire with no weights and it then took 1.25 once of weight and steering shake was gone. I think whoever balanced them just spaced it and forgot to add some weight? its all good now
steering wheel vibration xcitebike Vue General 22 06-08-2015 11:44 AM
70 mph+ vibration in steering wheel actionstan S-Series Tech 10 11-07-2013 05:44 PM
Steering Vibration chilipepper1327 Ion General 8 04-26-2011 09:45 AM
05 ION QC Steering Vibration Beemish Ion Tech 6 01-30-2006 02:01 PM
Vibration in Steering f150owner S-Series Tech 3 04-21-2000 09:43 PM
