#21 |
![]() Join Date: Dec 2021
All you need is one relay. Since the headlights always have power going to them and are turned on by the headlight switch itself making ground.
1. Unplug your high beam connector from the back of the headlight bulb. 2. Shave both wires down to accept a soldered connection. 3. Connect terminal wire 86 to one of the wires and 85 to the other. [It doesn't matter which one) Solder and tape the wires with electrical tape. 4. Unplug your low beam connector from the back of the headlight bulb. 5. Shave down the ground wire for a soldered connection and connect terminal 87 wire. Solder and tape the wire with electrical tape. 6. Connect terminal 30 to ground at body or battery. 7. Reconnect both headlight plugs. |
#22 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2012
I pulled out the upper core support after accident. I finally drove at night recently and realized lights were out of whack. I wasn’t sure if adjusting screw would even work. It Has never been touched. Seems ok now
saturn headlights | saturnsctwo | S-Series General | 28 | 11-17-2015 06:25 PM |
01-02 Saturn Sc1/2 headlights | cdxhizors | S-Series General | 8 | 06-20-2014 03:53 PM |
Saturn Ion Headlights | SaturnIONSLVUE | Ion Tech | 2 | 03-09-2009 11:31 PM |
HID headlights on a saturn? | turbobuick33 | S-Series Tech | 8 | 06-09-2008 10:36 PM |
Headlights For '94 Saturn Sc1 | cargo | S-Series Tech | 5 | 09-03-2006 10:51 PM |
