Old 09-24-2015, 08:47 AM   #1
todd8
todd8 has a spectacular aura abouttodd8 has a spectacular aura about
Default Driver's Side Brake Pic
This may sound like an odd request, but I was wondering if anyone has or can take a pic of the way the brake hose is routed on the driver's side (front) of an S-Series? I have a 1999 model and have been trying to track down a noise from the front wheel area when turning hard in reverse. The bearing and CV joint are fine, as are the pads and rotors. What I did notice was some chaffing on the plastic shield that covers the brake hose. After investigating further, I realized that the tire is actually hitting the hose when the wheel is turned to the all the way to the right.
On the driver's side the "bend" in the hose points to the front of the car, but on the passenger side, the "bend" in the hose is to the rear. Before I got too deep into this, I wanted to see the setup on another S-Series. My Haynes manual does not have such a picture and I could not find one on the web either.
Thanks much!
todd8 is offline   Reply With Quote
Old 09-24-2015, 09:03 AM   #2
Default Re: Driver's Side Brake Pic
Caliper is spun around the wrong way if the hose is rubbing on the tire; the hose bend goes behind the strut. Need to fix it before you need a brake line
The proper way to fix a S-Series automatic is to replace it with a manual
Old 09-24-2015, 11:59 AM   #3
^ Are you certain the caliper is spun around? Other than someone putting the wrong caliper on, calipers are right/left designs, the bleeder screws are offset. If I'm not mistaken, bleed screws are usually oriented towards the top. The brake fitting on calipers are more or less in the same position. If someone replaced the driver's side brake hose incorrectly, the hose may kink and rub the tire wall when turning full left or full right. Rubbing against the fender well is another indication of incorrect brake hose routing. The chassis side should have a hose clamp holding the hose in place.
Old 09-24-2015, 12:29 PM   #4
shortrun
shortrun is on a distinguished road
1995 SW2
I grabbed this off youtube, I think it is an S series?
I hope this doesn't break and rules, if it does I'm sorry and will delete it ASAP.
shortrun is offline   Reply With Quote
Old 09-24-2015, 02:52 PM   #5
See the pics here, and read post 2
http://www.saturnfans.com/forums/sho...d.php?t=139598
Old 09-24-2015, 03:26 PM   #6
todd8
Thanks to all for your help. It is appreciated!!!!!
Old 09-24-2015, 04:43 PM   #7
floridasl22002
Todd,
Check both calipers to ensure they are both the same type, albeit driver & passenger side. I can't believe that you may have 2 different calipers on your car, but stranger things have happened.
Old 09-25-2015, 09:27 AM   #8
todd8
Thanks again to all. I checked things out last night and sure enough, the caliper was spun around the wrong way! I simply turned it, the hose looped towards the back of the car and I reinstalled.
Another issue solved by Saturnfans!
2002 L200 - Hazard/Turn Signals not working. Plus driver's side brake light. gorollover L-Series Tech 2 04-21-2015 12:56 PM
Brake pedal moves side to side(has side to side play) journeyforce Aura General 5 07-27-2011 11:41 PM
Front Driver's Side Brake Caliper Stuck 2003 LW300 highertreetop L-Series Tech 4 02-08-2011 07:11 PM
Driver's side brake light out corn_dog S-Series Tech 7 03-26-2008 03:26 AM
Replaced brake light bulbs, now driver side not working right. Tiger S-Series Tech 12 11-11-2006 08:59 PM
