![]() ![]() Join Date: Apr 2005
This may sound like an odd request, but I was wondering if anyone has or can take a pic of the way the brake hose is routed on the driver's side (front) of an S-Series? I have a 1999 model and have been trying to track down a noise from the front wheel area when turning hard in reverse. The bearing and CV joint are fine, as are the pads and rotors. What I did notice was some chaffing on the plastic shield that covers the brake hose. After investigating further, I realized that the tire is actually hitting the hose when the wheel is turned to the all the way to the right.
On the driver's side the "bend" in the hose points to the front of the car, but on the passenger side, the "bend" in the hose is to the rear. Before I got too deep into this, I wanted to see the setup on another S-Series. My Haynes manual does not have such a picture and I could not find one on the web either. Thanks much! |
Caliper is spun around the wrong way if the hose is rubbing on the tire; the hose bend goes behind the strut. Need to fix it before you need a brake line
The proper way to fix a S-Series automatic is to replace it with a manual |
^ Are you certain the caliper is spun around? Other than someone putting the wrong caliper on, calipers are right/left designs, the bleeder screws are offset. If I'm not mistaken, bleed screws are usually oriented towards the top. The brake fitting on calipers are more or less in the same position. If someone replaced the driver's side brake hose incorrectly, the hose may kink and rub the tire wall when turning full left or full right. Rubbing against the fender well is another indication of incorrect brake hose routing. The chassis side should have a hose clamp holding the hose in place.
![]() Join Date: Jun 2015
1995 SW2
I grabbed this off youtube, I think it is an S series?
I hope this doesn't break and rules, if it does I'm sorry and will delete it ASAP. |
#5 | |
http://www.saturnfans.com/forums/sho...d.php?t=139598
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
Thanks to all for your help. It is appreciated!!!!!
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2014
Todd,
Check both calipers to ensure they are both the same type, albeit driver & passenger side. I can't believe that you may have 2 different calipers on your car, but stranger things have happened. |
#8 |
Thanks again to all. I checked things out last night and sure enough, the caliper was spun around the wrong way! I simply turned it, the hose looped towards the back of the car and I reinstalled.
Another issue solved by Saturnfans! |
2002 L200 - Hazard/Turn Signals not working. Plus driver's side brake light. | gorollover | L-Series Tech | 2 | 04-21-2015 12:56 PM |
Brake pedal moves side to side(has side to side play) | journeyforce | Aura General | 5 | 07-27-2011 11:41 PM |
Front Driver's Side Brake Caliper Stuck 2003 LW300 | highertreetop | L-Series Tech | 4 | 02-08-2011 07:11 PM |
Driver's side brake light out | corn_dog | S-Series Tech | 7 | 03-26-2008 03:26 AM |
Replaced brake light bulbs, now driver side not working right. | Tiger | S-Series Tech | 12 | 11-11-2006 08:59 PM |
