Old 07-11-2012, 12:19 PM   #1
flyhop
flyhop is on a distinguished road
2000 SL2
Default Coolant/water ratio too high?
Long story short, I added straight coolant when I thought it was a gifted bottle of 50/50 diluted mixture. Best I can figure, I have 80/20 mixture in car.
As I have just put in a new ECTS, t-stat, water pump and radiator hoses, I sure don't want to have a coolant ratio that will do damage.
Thanks.
flyhop is offline   Reply With Quote
Old 07-11-2012, 12:20 PM   #2
dbsanfte
dbsanfte is on a distinguished road
1999 SW2
Default Re: Coolant/water ratio too high?
The highest you should ever really go, ever, is 70/30, and that's for Alaska or Northwestern Ontario in the dead of winter Drain some and dilute that a bit.
dbsanfte is offline   Reply With Quote
Old 07-11-2012, 12:27 PM   #3
flyhop
2000 SL2
Short of a turkey baster in the reservoir tank, how does one go about pulling out a little coolant?
Old 07-11-2012, 12:30 PM   #4
dsquare86
dsquare86 is on a distinguished road
2002 SL1
2001 SL2
Very carefully open the radiator drain to allow about a quart or so into a bucket.
Derek
2002 Saturn SL1 SOHC 5 Speed.
2001 Saturn SL2 DOHC 5 Speed - Retired.
dsquare86 is offline   Reply With Quote
Old 07-11-2012, 12:31 PM   #5
todd8
todd8 has a spectacular aura abouttodd8 has a spectacular aura about
There is a small petcock drain on the radiator - passenger side. It's plastic, so becalf when turning.
todd8 is offline   Reply With Quote
Old 07-11-2012, 12:39 PM   #6
flyhop
2000 SL2
I know what you mean...I had some fun with that drain two days ago.
Just for fun, I'm going to ask.
Is there a way to determine the actual mix ratio I've got in there now? Would a hydrometer work? I've got two in my homebrew stuff.
Old 07-11-2012, 12:49 PM   #7
dsquare86
2002 SL1
2001 SL2
They sell antifreeze testers at parts store and even Wal-Mart that will tell you that. I haven't ever used one myself other than to suck brake fluid out of my reservoir. Somehow I don't think that was in the instructions.
Derek
Old 07-11-2012, 01:02 PM   #8
Thanks.
That will hurt nothing at all. If it is a concern just siphon 1 1/2 quart of mixture out of teh reservoir (it holds almost 2 quarts) and refill with distilled water. Draining from radiator is not a good idea
The magic technique is siphon.
Old 07-11-2012, 04:41 PM   #9
"Coolant disaster" thread was just a few threads down
http://www.saturnfans.com/forums/sho....php?t=181959#
Old 07-11-2012, 07:53 PM   #10
In the coolant disaster thread, the magic words are Refractometer, eBay, $25.00
Coolant / Water Light Sixx S-Series Tech 9 05-15-2012 08:59 AM
Running through high water Sidneyaks S-Series General 15 06-29-2011 07:44 AM
Low coolant level and High coolant/transaxle fluid temperature nls S-Series Tech 2 08-30-2009 09:46 AM
Stalled while Going Through High Water. Now Knocking. JohnnyRudick S-Series General 9 07-01-2008 12:25 PM
Change water coolant!! epekarik L-Series Tech 8 09-25-2005 09:44 PM
